Deere 455 Coolant drain plug metal bolt missing
   / Deere 455 Coolant drain plug metal bolt missing #11
boomer
Do you know if a petcock has the correct thread size?
If not, won't work well.
   / Deere 455 Coolant drain plug metal bolt missing #12
boomer
You should be able to find a petcock with the correct size thread. My best guess it metric pipe thread, since it's called a plug and after looking at the pictures. Take your ruler and check out the hardware and auto parts stores.
   / Deere 455 Coolant drain plug metal bolt missing #13
I drained all the coolant on my Deere 455 tonight. Unfortunately, the metal coolant drain plug bolt on the engine has been lost.Any suggestions or advice would be greatly appreciated.Mike
Mike, You did check the container into which you drained the old antifreeze I hope? For that kind of price I would look harder for the original plug.
   / Deere 455 Coolant drain plug metal bolt missing #14
That plug sits directly behind the fuel filter unit, so suspect no extra room for a petcock.
I'd be getting one from the Deere dealer.. if were me and I was the one that lost it.. the price to pay :D
Cheaper than the goof-up my neighbor did.. changing oil in his Gator and after adding 1/2 qt of new oil, had a business emergency phone call that took over three hours. After several hours (50 miles driven) of use that the engine was started to falter and no power. Sputtered but would idle. Booked some free time to look into why, and then spied the full quart of oil on the bench that he'd forgotten to add.
Had to pony up for a new engine, when the fried one only had 50 hours on it.
Yes, I did look in the drain pain. No luck. If anyone has any advice I am all ears. Also, I updated my original post with photos of the original bolt.
   / Deere 455 Coolant drain plug metal bolt missing #16
Get a roller magnet and push it back and forth over the general area where you think it dropped...
   / Deere 455 Coolant drain plug metal bolt missing #17
Did you look in the socket you removed it with?
I have been known to lose hardware and then find it the next time I used that socket.
   / Deere 455 Coolant drain plug metal bolt missing #18
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
7022 (A50322)
7022 (A50322)
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
2022 New Holland Powerstar 110 Tractor with Loader (A51573)
2022 New Holland...
Payment Terms (MUST READ) (A50775)
Payment Terms...
