Kubota B7800 Axle Removal
   / Kubota B7800 Axle Removal #1
bluesbass
West Virginia
Kubota B7800HST
Hi folks I am new here. I have a B7800HST with 900 hours. The front axle pivot began squeaking/squawking very loudly. I decided to rebuild the pivot point replacing the busing and seals. I got the axle case removed from the tractor, got the front, axle bracket removed, but can't get the rear axle bracket off the boss on the axle case. These are the two brackets that hold the axle case on the tractor and the point where the front axle pivots.
Is there anything that holds the rear bracket on the axle case or do I just need to use more force to remove? Any ideas on how to remove? I am guessing this is where my problem is. Likely the bushing has failed and maybe contributing to the problem of not being able to separate from the axle case.
Thanks
Thanks
Never mind. I got it off with lots of hammer and blaster.
   / Kubota B7800 Axle Removal #4
I think he ment bluster, not C4, 3C etc. I always like dynamite rather than AMFO in any application.
   / Kubota B7800 Axle Removal #5
I assume that he meant "PB Blaster"
It is great stuff!
Yeah it was PB Blaster The B'laster Corporation |
I got it all back to gather and working fine. The rear bushing and all had rusted and was was worn. It was a chore to get it out and replace but all good now. I considered putting a grease fitting on it but didin't. Thanks all.
   / Kubota B7800 Axle Removal #8
Should have put a grease fitting it, lol!!
David from jax
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
UNUSED FUTURE SF60 HYD MAST W/ 60" FORKS (A51248)
UNUSED FUTURE SF60...
23222 (A50323)
23222 (A50323)
UNUSED HURRICANE D6028 - 5' JOB BOX (A51248)
UNUSED HURRICANE...
CONTACT INFO (A53084)
2021 Honda Foretrax Rancher (A51573)
2021 Honda...
