jimmy robinson
Member
You guys have been so helpful and I do thank all of you!
I am actually a newbie when it comes to tractors.
My problem: I have this TO 35 1953 4 cylinder gasser. This tractor has been sitting up for 3 years. I cleaned breather fuel tank, plugs plug wire dist cap points new coil new solenoid. When I first got the tractor home I put a new fully charged 6 volts battery on and tried to crank engine checking to see if engine might be seized.
The engine slowly turned over and was not seized. After turning engine over it will not attempt to turn again. I removed the starter and did the check to see if it would spin and kick bendix in and out ( worked fine). Put the starter back on replace the solenoid . Still nothing even with spark plugs removed.
I have spark to points, solenoid, have not replaced voltage reg. Have replaced ignition switch.
Will a 4 pole 12 volt solenoid on a 6 volt system work?
Should I replace the voltage reg?
I would appreciate any and all input. I am not knowledgeable on tractors so bare with me!
Thank you in advance.
