1952 Ford 8N w/side mount distributor will not start
   / 1952 Ford 8N w/side mount distributor will not start #1
dknonnie
Kannapolis
1952 ford 8n 12 volt side mount distributer
I have a 1952 ford 8n tractor with side mount distributor. It will not start. There is fire at the points but but at the plugs. New wires, distrubutor cap, plugs with gap verified .025. Everything checks good before points. I have read many posts regarding no fire but have not found an answer.
thank you
   / 1952 Ford 8N w/side mount distributor will not start #2
Re: dknonnie
:welcome: Welcome to the forum.
I'm going to move this thread over to our vintage Fords section to see if we can find you some help.
Re: dknonnie
We have determined there is spark to new plugs but still no start.
   / 1952 Ford 8N w/side mount distributor will not start #4
You need a correctly timed spark, compression, and the correct air/fuel mixture.
Thank you
We did verify spark order. Has new coil, distributor cap, points, plugs, and wires, condenser, & carburetor.
   / 1952 Ford 8N w/side mount distributor will not start #6
Does it kick over if you spray ether into the air intake?
Aaron Z
   / 1952 Ford 8N w/side mount distributor will not start #7
Does the 8n still have the positive ground system? That means the positive side of the coil should be hooked to the points.
A neg ground system has the neg side of the coil hooked to the points.
If it is backwards, you still may have spark but it will be weak.
   / 1952 Ford 8N w/side mount distributor will not start #8
if the plugs will spark with max gap.. move on to fuel and timing.
post back.
Thank you for your time, looking kike may not begin yo try your suggestions until after the 4th holiday. Will do though! thanks again, will let you know.
   / 1952 Ford 8N w/side mount distributor will not start #10
Good luck, be safe, post back.
JOHN DEERE 7210R LOT NUMBER 264 (A53084)
JOHN DEERE 7210R...
Как зайти с телефона на кракен. kra39ac.cc  | Kraken зайти на площадку? как пополнить кошелёк? Правила диспута
Как зайти с...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2012 Kia Sorento SUV (A51694)
2012 Kia Sorento...
2018 Kia Soul Crossover SUV (A51694)
2018 Kia Soul...
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
