Found something strange on my BX23S Fuel Injection Pump
   / Found something strange on my BX23S Fuel Injection Pump #1
BX23S-1
No Clue
Kubota BX23S
I noticed this weird thing on the backside of my injection pump. This little thingamajig just sits there and spins and rattles around, so look at the picture and see if any of you know what this is. It faces towards the rear of the engine, towards the radiator. Its loose and just spins freely while the engine runs. It has a flat only on one side of it, looks like some sort of pin inside of the middle of it. It looks like it has something to do with the injection pump, but i`m clueless to what it is. I`m just concerned that it sits there spinning from engine vibrations.
   / Found something strange on my BX23S Fuel Injection Pump #2
When I get some time I'll if its the same on mine.
GenLee, if you find it, see if yours is just loose and spins around too.
If yours is the same, i`m not gonna worry about it. But it would still intrest me in knowing what it is.
   / Found something strange on my BX23S Fuel Injection Pump #4
I think it's the anti-tamper cover for the FIP adjustment? It spins so the screw it covers doesn't. Leave it alone.
:wrench:
   / Found something strange on my BX23S Fuel Injection Pump #5
Yep, mine spins. I didn't check it while engine was on. Found it, felt it and it's loose
Thanks for looking into it GenLee, i feel alot better about it knowing others have the same thing.
:wrench:
Thanks, and i have absolutely no intentions of messing with it.
If i dont know what something is, i dont touch it, i always ask others first.
I was just curious as to what it is and what it does because it just sits there spinning/rattling around.
   / Found something strange on my BX23S Fuel Injection Pump #8
No problem. Its good to be able to check with others about things on the same model tractor.
PAIR OF SINGLE AXLE TRAILER FENDERS (A51247)
PAIR OF SINGLE...
UNUSED CHERY INDUSTRIAL 11' CATTLE SQUEEZE CHUTE (A51248)
UNUSED CHERY...
2010 Chevrolet Tahoe SUV (A52377)
2010 Chevrolet...
1839 (A51248)
1839 (A51248)
2018 Case TR270 High Flow 2-Speed Compact Track Loader Skid Steer (A51691)
2018 Case TR270...
UNUSED AGT TSOCPF48 MAST W/ 48" FORKS (A51248)
UNUSED AGT...
