mf 204 keeps braking starter nose cone WHY please help
   / mf 204 keeps braking starter nose cone WHY please help #1
fleeman1965
maybee michigan
massey ferguson 204
please help I have replaced starter 3 time over the years and it brakes a starter about every year or 2 I was just wondering could it be the wrong gear on the starter not meshing with the teeth on the flywheel flywheel looks to be in good shape starter bolts are always right any help or suggestions would be appreciated thanks in advance
   / mf 204 keeps braking starter nose cone WHY please help #2
Sounds like an old Chevy in need of shims. Old Chevys had shims where the starter mounted. Not shimmed enough, they could break teeth on the flywheel, starter, or crack the starter housing. Shimmed too much, it'd round the teeth off the gears.
If you had improper gear on the starter, the flywheel wouldn't look to be in good shape. Especially after going through 3 starters.
   / mf 204 keeps braking starter nose cone WHY please help #3
There should be a thrust washer on the shaft where it goes into the nose cone.
   / mf 204 keeps braking starter nose cone WHY please help #4
Make sure that all of the teeth on the flywheel ring gear are in good shape.
Case 1020 25ft Draper Head (A53473)
Case 1020 25ft...
2013 Ford Explorer SUV (A51694)
2013 Ford Explorer...
2018 Lexus IS300 Sedan (A51694)
2018 Lexus IS300...
2014 INTERNATIONAL DURASTAR 4400 SERVICE TRUCK (A51406)
2014 INTERNATIONAL...
2012 Mack GU713 T/A Gardner Denver Kill Truck (A52377)
2012 Mack GU713...
