Removing Kubota Hydraulic Quick Disconnect Couplers
   / Removing Kubota Hydraulic Quick Disconnect Couplers #1
ballegre
NC
Kubota L3010 2000
I have a 2000 Kubota L3010 and an LA481 FEL. Several hoses are leaking. In the process of replacing them I discovered that I cannot remove a single coupler from the old hoses to the new ones. They are all stuck. I tried heating with a blow torch and broke a mini vice in the process.
Can I take these hoses to a shop and ask them to remove? Or is it just standard practice to order new couplers with hoses because they are impossible to remove?
Thanks,
Bob
   / Removing Kubota Hydraulic Quick Disconnect Couplers #2
Bob: They unscrew. Maybe you needed a bigger vice to hold them?
Grip the hose hex in a proper vice and apply your spanner to the coupler hex. Not the other way around.
Don't use heat on hydraulic components.
Regards,
:wrench:
   / Removing Kubota Hydraulic Quick Disconnect Couplers #3
If you used a "blow torch" then the seals inside are probably wrecked now.
   / Removing Kubota Hydraulic Quick Disconnect Couplers #4
Yaa, get a proper vise. They will unscrew. But agree with KennyD. PRobably should buy new couplers now as the rubber seal inside is likely shot in the ones you applied heat to.
Thanks for the replies.
I used a propane torch not a blow torch (my bad). I did take them to my mechanic who put them on his industrial sized vice and using a torque wrench with a 22mm deep socket removed them in about 10 seconds. I wasted nearly half a day. Gotta have the tools.
Mechanic, who had his Kubota in his shop at the time, said the nipple looked fine to him. No damage from the heat. I put it on the tractor and cut the now 3 foot grass in my field for a few hours. I didn't see any leaks (so far).
   / Removing Kubota Hydraulic Quick Disconnect Couplers #6
Glad you got it fixed. Thanks for updating us:thumbsup:
   / Removing Kubota Hydraulic Quick Disconnect Couplers #7
A propane torch or any torch is easily capible of melting plastic & rubber. I'd replace the couplers rather than mess with likely melted seals.
2017 Ford F-450 Crew Cab Mason Dump Truck (A53422)
2017 Ford F-450...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
2015 VOLVO L90H WHEEL LOADER (A52705)
2015 VOLVO L90H...
(INOP) CATERPILLAR 314 EXCAVATOR (A51247)
(INOP) CATERPILLAR...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Altec AT41M Boom (A53473)
2016 RAM 5500...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2019 FREIGHTLINER...
