Why two levers for front-wheel drive and differential lock?
   / Why two levers for front-wheel drive and differential lock? #1
billattractorbynet
Broad Run, VA
Kubota RTV500
I've driven a few Kubota ATVs over the years, and all have had a single 2WD/4WD lever. I understand what's going on there.
My new RTV500 has one level for differential lock, and one for four-wheel drive. I believe that I understand the mechanics of the two levers. My default back wheel drive is one drive wheel, and the differential lock lever gives me two drive wheels in the back. The four-wheel drive lever gets the front wheels pulling.
So, I get that in snow plowing, I'm probably going to want both engaged to give me all the power I need. What I'm curious about is what scenarios, if any, would I want one lever or the other, but not both.
So:
  1. What scenario(s) would I want the differential locked on the back wheels but not four-wheel drive?
  2. What scenario(s) would I want the four-wheel drive on for the front wheels but not the differential locked in the back?
Thanks in advance for any replies! :)
   / Why two levers for front-wheel drive and differential lock? #2
You don't want the diff lock on when turning. When you make a turn the wheels need to rotate at different speeds. 4WD on is OK since the front and rear differentials allow the wheels to turn at different speeds. When the diff lock is on both rear wheels are locked together and is mainly used for going in a straight line.
Thanks, George. That's what I was looking for.
So, what I'm piecing together is that an ATV with only a four-wheel drive lever probably doesn't have the differential lock capability. Interesting.
   / Why two levers for front-wheel drive and differential lock? #4
I believe most ATV's are permanent "limited slip" differential, few are permanent locked different, and some may be selectable. IMHO, at slow speeds, you should lean and put your weight on the outside tire in a sharp turn so that the inside tire can spin/slip without weight on it and lessen tearing up your lawn or laying rubber on your driveway.
   / Why two levers for front-wheel drive and differential lock? #5
So:
Whoa! Stop the bus!!
People are on a tangent... and you do not understand your machine when you say:
The RTV500 is a Rugged Terrain Vehicle (and not a Quad Bike where you sit astride the engine/fuel tank.)
The Rear drive is the 2WD setting which gives you drive in T W O wheels with a differential. (Each wheel can rotate at differing speeds when cornering) No 'leaning needed' !!
Diff Lock "Locks" the diff and converts the rear drive into a 'solid' drive (Both rear wheels turn as one)
4WD adds the two front wheels as driving wheels eg. for muddy/soft ground. So you have F O U R wheels driving.
Never engage 4WD on hard ground such as concrete/asphalt.
Since the machine is 'new' to you go back to your dealer and get the Sales person to provide proper instruction of the various features.
:wrench:
   / Why two levers for front-wheel drive and differential lock? #6
I will add a bit to this discussion and speak in generalities since I do not know your vehicles capabilities. There are lots of functional options for the term 2WD and 4WD.
- Typically, 2WD actually means 1WD since the standard axle is an "open differential" that delivers most of the power to the wheel with the least traction. This is useful for turning with minimal tire scrubbing on hard surfaces and nice grassy areas as the inside and outside tires will turn at different speeds. Actual 2 driven wheels would involve either a single axle shaft with no differential, a locking differential for the axle or a limited slip type of differential clutch using springs or hydraulics (for example) under manual or computer control.
- 4WD can be a large misnomer also as it can simply be 2WD x 2- meaning it can have 2 wheels driving (1 front and 1 rear) or 3WD or true 4WD, depending upon equipment used. See 2WD options above. Typically a manually locked front differential can be a difficult handler and needs to be used very judiciously and at slow speeds.
- AWD on a modern vehicle is typically computer controlled and closet to a true 4WD system, depending upon how it is applied/controlled and will vary the amount of wheels driven depending upon feedback from the wheels to the computer. My Jeep is AWD.
My 2016 Polaris Ranger 900 XP has three switch selectable modes of operation: 1- open rear differential (standard 2WD with one wheel driving), 2- locked rear differential (real 2WD) and 3- AWD where the computer selects which of the 4 wheels to drive depending upon feedback (slippage/wheel spin) and how much power to supply each wheel. I usually use it in open rear axle (1WD) or AWD. In AWD I have pulled my wife's stuck 2000 Toyota Tacoma 2WD out of the sandy area it was mired in with nary a wheel spin from the Polaris. In locked 2WD it was spinning the rear wheels and not making any headway.
My 2015 RAM 2500 diesel can be 3WD with a locked rear differential in 4WD mode. I need to investigate further but recall seeing something somewhere about the front axle having the capability of being locked also; I do have a 4WD locked option on a switch and this may do it. Or maybe not.
My tractor in 4WD in actually only driving 1 front and 1 rear wheel. I can lock the rear differential to effectively get 3WD or unlock the brake pedal combining lever and with judicious use of the brake pedal on the spinning rear wheel get additional traction without using differential lock.
Thank you. That was extremely helpful. :thumbsup:
I will add a bit to this discussion and speak in generalities since I do not know your vehicles capabilities. There are lots of functional options for the term 2WD and 4WD....
   / Why two levers for front-wheel drive and differential lock? #8
Extremely incorrect.
2wd means just that. BOTH wheels are driving.
One wheel spinning and one not does NOT mean its a one wheel drive.
An open differential means that BOTH wheels will apply the exact same amount of torque to the ground.
Hypothetically, lets say it takes 20 ft-lbs of torque to move the vehicle. IF one wheel is in the air, on ice, in mud, etc it takes very little torque to make it spin. Say 5 ft lbs of torque. With an open differential, that means that only 5ft lbs is being applied to the wheel that is in the air, on ice, in mud, etc and doesnt get you the required 20 ft-lbs needed to move the vehicle and you are stuck.
An open differential quite simply is EQUAL torque, UNEQUAL speed.
Where as a locker makes it UNEQUAL torque, EQUAL speed. So with a locker, while one wheel may only get 5ft lbs before it wants to spin, you can keep applying torque til the one with good traction starts a rolling. So...if the tire with good traction can get above the hypothetical 20 ft-lbs and still have grip, you will move.
Get so sick of ill informed people claiming that a 2wd is really a 1wd without a locker or LS, or hearing people claim their 4wd truck is really only a 2wd truck.
Open differentials have their place. They are good on ice because you are less likely to fishtail. And they are good on a road vehicle because you arent constantly scrubbing tires, getting wheel hop in turns, and are generally easier on the drive line.
Now how it relates to the RTV with basically 4 options
1. 2wd UNLOCKED....use this most frequently running around where traction isnt a prime concern
2. 4wd UNLOCKED ....USe this is its snowy, or soft, or when you otherwise need more traction that you dont think 2wd will do
3. 2wd LOCKED in.....Only use I can think is if you want to do some donuts in the snow/ice or in the mud
4. 4wd LOCKED in.....Use if 4wd unlocked fails you. This is a last resort before getting something to pull/winch you out
   / Why two levers for front-wheel drive and differential lock? #9
Thank goodness someone else also understands the principle of the automotive "Differential".
Referencing 1WD and 3WD is, indeed, incorrect.:irked:
Good post LD1 :thumbsup:
:wrench:
   / Why two levers for front-wheel drive and differential lock? #10
:wrench:
This topic comes up every once in awhile. As does certain hydraulic principals. It astounds me the number of people who just don't understand.
All I can do is try my best to educate those that don't understand
7ft Metal Texaco Pump (A57454)
7ft Metal Texaco...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2015 Kenworth T880 QMC 8060R 50 Ton Tri Axle Crane Truck (A60460)
2015 Kenworth T880...
Dayton 32965 80-Gallon Horizontal Air Compressor, 22 Volts, 5 HP, 2 Stage, 3 Phase (A59076)
Dayton 32965...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
