Kubota Bx question
   / Kubota Bx question #1
Tractorrr
Gold Member
TN
kubota bx 2370-1
I have noticed a few times that while mowing uphill in fairly thick grass that the RPM's have dropped from about 3400 to 3100 or so and return to 3400 at the top of the hill or in thinner grass. I noticed that it does this in high gear but not really in low. This is a pretty much new Kubota bx 2370-1 with about 35 hours on it.
Just looking for opinions on whether this is pretty normal or what. Is that considered lugging the engine to have a small drop in RPM's like that? I wouldn't think it is too harmful but thought it would be better to ask. Thanks
   / Kubota Bx question #2
When I cut grass with my BX2660 using my rear finish mower, I typically run the engine rpm at around 3000 at most , and I only cut in low gear, I would never attempt to cut in high gear unless it was very shallow grass cutting. I wouldn't even think of using high gear on a hill cutting deep grass. It would definitely bog down RPM in high gear. But that is just me maybe.
   / Kubota Bx question #3
Way back in 2009 when I owned a BX2660, I mowed "grass" in low gear. And IIRC the rpm was on the red line. I believe the High gear was for road travel IIRC.
   / Kubota Bx question #4
What transmission does your BX have? HST or gear?
   / Kubota Bx question #6
HST is most efficient at low RPMs: i.e. starting off.
The small drop you are experiencing is probably related HST operating a slight bit less efficiently as you power up hill at higher RPMs, working at a point slightly less efficient for the HST.
Ok yeah I was thinking this is pretty normal. Thanks.
   / Kubota Bx question #8
Did the dealer tell you how to use the HST? When the engine is working hard, you BACK OFF the HST pedal instead of flooring it like you would the gas pedal in your car. That's because the pedal adjusts the gearing instead of the engine rpm. Light on the pedal = lower gear/more pulling power; heavy on the pedal = higher gear/faster ground speed. You may have a combination of slope and heavy grass that is bogging the engine a bit... adjust your driving technique and see if it helps. Others are right that going to Low range on a hill does the same thing. I've always used High range for mowing on generally level ground. It's about impossible to bog the engine, but you have to slow down to let the deck clear the discharge and cut all the stems.
Yes I know about backing off the HST for more power. The engine didn't seem to bog in low gear but I would prefer to mow in high most the time. I guess I am wandering if bogging the engine a little bit while mowing is bad for it or not? Is a drop in 200 to 300 RPM's a bad thing?
   / Kubota Bx question #10
On a hill in high, with the mower going and thick grass - yep totally normal. Should be shipping to low for that. It will give you a ton more power and keep the heat down. That is sort of like locking a car in overdrive going up the mountain, it may do it but it working really hard when there is a much better "gear" available.
We are very hilly and it is normal for me to shift from high to low a few times a day mowing on my BX25. kick in in low, do the steep hills then shift it to high for the fields. I even have to shift my 50hp on the big hills to a lower HST range if I am running the brushhog or something that takes power.
Toro Workman 200 Sprayer Cart (A50324)
Toro Workman 200...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2018 Ford Transit 250 Cargo Van (A51692)
2018 Ford Transit...
UNUSED WOLVERINE GB-11-72W-72" HYD GRAPPLE BUCKET (A51248)
UNUSED WOLVERINE...
2021 MACDON C3812 LOT NUMBER 33 (A53084)
2021 MACDON C3812...
City of Buckhannon - Power Curber 5700 (A52384)
City of Buckhannon...
