First Oil Change X590 -- Oil Filter Wrench?
   / First Oil Change X590 -- Oil Filter Wrench? #1
tguil
JD 1070
Getting ready for the first oil change (8 hours) on my 2016 X590. A small strap filter wrench will not work. Not enough room to get any leverage. If it is like any other factory oil filter that I have attempted to remove, the filter is going to be on darn tight. (That's why I always have the dealer do the first oil change on my trucks. If they mess up, it's the problem not mine.) Any suggestions for a problem free removal of this filter? Any wrenches made just for this tractor?
   / First Oil Change X590 -- Oil Filter Wrench? #2
It is easy to just buy the wrench that fits the filter .
I have three for different size filters they are cheap .
   / First Oil Change X590 -- Oil Filter Wrench? #4
I use a large channel lock wrench to remove.. hand tighten tho.
   / First Oil Change X590 -- Oil Filter Wrench? #5
I just did the first oil change on my x590. I picked up the oil filter wrench from my John Deere dealer before performing the oil change as I had read many stories of difficulties removing the filter. The oil change went smoothly with the wrench.
OK, thanks for the suggestions. I have the the Deere wrench. Is it necessary remove the side panel to get at the filter and remove it completely. It's a tight fit. If you remove the panel, how? It appears that there is only one screw attaching the panel to the frame.
   / First Oil Change X590 -- Oil Filter Wrench? #8
you dont have to take panel off, but easier if you do, it comes off with the 1 screw ( if I remember correctly ) take 2 min or less
Thanks, that's what I thought.
   / First Oil Change X590 -- Oil Filter Wrench? #10
I'm a big fan of this type of filter wrench. It's geared inside so as you turn counter clockwise the teeth bite in. One size fits all. :)
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2013 Ford F-150 Pickup Truck, VIN # 1FTFW1EFXDFB07930 (A51572)
2013 Ford F-150...
2012 GOOSENECK TRAILER MFG.,CO, INC TANDEM AXLE MANIFOLD TRAILER (A52472)
2012 GOOSENECK...
2015 PETERBILT 567 TRI-AXLE (A52472)
2015 PETERBILT 567...
2018 John Deere 460E Articulated Dump Truck (A53472)
2018 John Deere...
Wright Sentar (A50120)
