massey ferguson 202 won't start
   / massey ferguson 202 won't start #1
01hunter570
I have a massey ferguson 202 workbull that used to run fantastic. the power steering pump started leaking fluid into the engine oil pan and it sat for about a year. before this in the coldest of weather I would pull the choke out and as soon as it started spinning push it back in and it would start right up. I finally got around and bought a new $500 steering pump as it has a loader on it and I figured where could I buy a loader for $500. after I got the new steering pump on it I had a hard time getting it started. I finally got it started but even after it was warmed up it would not run without the choke half way out. that was last summer and after setting over the winter I can't get it started again. I took the carburetor off and cleaned out all the jets and made sure the float didn't have a hole in it. it still won"t start, the plugs are dry. I was wondering if anyone knows if the intake manifold gasket could be the problem? don"t have any experience with this type of carburetor mounted under the intake, I think it's called an updraft carburetor. any thoughts on solving this problem would be greatly appreciated. thanks 01hunter570
   / massey ferguson 202 won't start #2
Unscrew the fuel line at the carb and see if gas runs out. Sounds like a fuel supply problem if the plugs are dry. Check for filters from inside tank to carb. Or water in fuel.
Jim
Jim
thank you for your reply jimmysisson. I have already checked on water in fuel, none. I also when I had the carburetor off for cleaning, opened the petcock on the fuel shutoff and I had fuel running out at the carburetor end. like I said last summer when I got it running even when it got warmed up I had to run half choke to keep it running. i'm wondering if the intake manifold gasket leaking could make it act like this? it is definitely not getting fuel to the cylinders. thanks again for your time.
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
1264 (A50490)
1264 (A50490)
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
Kinkaid 1200 LS-PH Towable Hydroseeder (A51691)
Kinkaid 1200 LS-PH...
2016 (INOPERABLE) FREIGHTLINER SD122 (A52472)
2016 (INOPERABLE)...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A52748)
Koyker Loader...
