Heavy toothbar w/cutting edge vs. Piranha question from new owner
   / Heavy toothbar w/cutting edge vs. Piranha question from new owner #11
back story, I ordered a toothbar with my L-47 TLB but somehow the salesman didn't get it ordered and there were none in stock when I picked the machine up. He was kind enough to give me a 72" non brand specific toothbar (no charge) that was in stock. It fits the bucket, however, it's designed to be used with a 3/4" cutting edge on the bottom of the bucket. Without the cutting edge it's sort of whopperjawed sitting in the bucket but would probably work. So far I can not find a bolt on cutting edge with the same hole pattern thats on my bucket, which seems to measure at 6-1/4" oc. Additionally the least expensive I've found is from Titan for about $150, and then I'd have to drill the holes myself. Not exactly looking forward to drilling through 3/4" hard steel....
So my question is, is there a better solution for the cutting edge, or should I nix that idea and just go with the Piranha I've read so much about? My machine is pretty heavy duty but it's only for use around my property and one of the main tasks will be clearing about 6 acres of scrub. No heavy duty construction jobs or serious digging.
Opinions appreciated, this seemingly simple problem is giving me fits.
I highly recommend the Piranha tooth bar. It makes digging much easier and grabs saplings and rips them out. I also have a Ratchet Rake. If I could only buy one the Piranha would be the best choice hands down!
   / Heavy toothbar w/cutting edge vs. Piranha question from new owner #12
Thanks alot!!!!:confused3: You may have just cost me another $300+ for a Piranha for my L3901. My RR does not grab the saplings and pull them out but peels them as it slides over them and then they flip back up as I go by.:mad: I bought the L3901 with jerking 2" to 3" saplings out of the ground as one of the main needs. You saying the Piranha will do that when the RR won't?
   / Heavy toothbar w/cutting edge vs. Piranha question from new owner #13
Yes I've had good results with it pulling out honey suckle, etc. It bites into the tree or bush. I need to make a video of it sometime soon!
   / Heavy toothbar w/cutting edge vs. Piranha question from new owner #14
My RR does the scrub stuff like honeysuckle and water sprouts, weeds, trash stuff but not the 2" to 3" poplar. maple hickory walnut trees that are about 6' to 10' tall. Those are what are causing my issue. Are the teeth of the Pirinha that sharp to slice into a tree and grab it? Sharper than the RR? I've thought about sharpening a few of the teeth on the RR to see if they would grab or just peel the tees easier.
   / Heavy toothbar w/cutting edge vs. Piranha question from new owner #15
Yes they are very sharp. Like a chisel. The teeth will either pull tree out or slice it off.
   / Heavy toothbar w/cutting edge vs. Piranha question from new owner #17
Thanks. I guess I'll try one. It's only money.:D
   / Heavy toothbar w/cutting edge vs. Piranha question from new owner #18
Will be interesting to see what you think. Make sure you call them when you order. They are made to fit your bucket.
   / Heavy toothbar w/cutting edge vs. Piranha question from new owner #19
They have the different sizes/widths on their site where I got the price for the one for my L3901 but I'll call if I order. I got to thinking about my Rip and Dig Rip and Dig maybe being good for popping out the small trees better and then got to wondering if the Rip and Dig will fit over the Pirinha installed on the bucket. What do you think?
   / Heavy toothbar w/cutting edge vs. Piranha question from new owner #20
I bought the Piranha for my BX as I didn't want to do all the drilling to add the cutting edge. As someone here said it's like adding horsepower when it comes to digging. It also improves the ability to clear brush and doesn't hinder back dragging. Two holes to drill; very straightforward. I'm pleased. John in PA
2006 GMC C8500 Altec DM47 47ft Digger Derrick Truck (A55852)
2006 GMC C8500...
Swict 84" Quick Attach Bucket (A56469)
Swict 84" Quick...
UNUSED FUTURE EQUIPMENT SEAT (A57193)
UNUSED FUTURE...
MAHINDRA MAX 26L LOADER (A57192)
MAHINDRA MAX 26L...
Adams 5T High Clearance Fertilizer Spreader (A55301)
Adams 5T High...
