gc1705 guidance please
   / gc1705 guidance please #11
I have not found float either.
Greetings Edgarrian,
Finding the float position on our GC1700s is a summer and winter benefit. In winter you can plow concrete and blacktop of snow and ice using your bucket and in summer you can backdrag our buckets like a champ. Ice removal is so much easier.
What some don't realize is that fel bucket float is two actions not one. The float choice is an up and down effect that puts the bucket and fel arm weight to the ground in a fixed setting . . that's the simple to understand part. But our bucket's also tilt and curl and the tilt and curl continues to operate at your adjustment control while still in float mode.
So in forward direction tilt can change how much edge digs into the surface and curl rides/flattens over surface. In reverse the same concept either smooths (curl) or drag brooms (tilt).
I'm not bad at normal backdragging to level manually. . . but in float mode using tilt/curl I'm almost as good as a seasoned landscaper or excavator.
And using the bucket for snow removal was neither easy or driveway beneficial till float was discovered lol.
   / gc1705 guidance please #12
Ill have to try the 130 to 200 angle. I had tried straight up and couldn't get it. Really not a big deal to me as Im able to load my bucket without gouging. Ill be home in 4 weeks thats the crappy part. Here's to hoping it goes by quickly
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
UNUSED FUTURE MCLG60 CURVED LOG GRABBER (A57193)
UNUSED FUTURE...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
2024 John Deere 6110M MFWD Tractor (A53485)
2024 John Deere...
(2) SLIP ON 82' FORK EXTENSIONS (A57193)
(2) SLIP ON 82'...
2016 Mitsubishi Fuso FEC52S Cab and Chassis Truck (A55852)
2016 Mitsubishi...
