CalG
Super Member
- Joined
 - Sep 29, 2011
- Messages
 - 9,012
- Location
 - vermont
- Tractor
 - Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
The fights of the blower have seen so much scraping that the edges are all rolled over and bent.  I went all over the elements with a pair of heavy hammers to bring things closer to right,  But I can't put metal back on with hammers.
In past years I have built up damaged areas of the auger flights with SMAW, but this time I've got the auger pulled for new bearings, and want to do the repair "right".
A few hours were spent today with the small side grinder taking off the "burr" that had formed continuously on all four flights. I'm happy to see those gone, as they were like razor wire looking for blood.
I'm going in to the metal mongers shop tomorrow and coming back with either 25 feet of 3/16 or 1/4 steel wire and 10 pounds of 6000 series filler rod, or 10 pounds of hard facing / build up rod. (I know which will be less costly ;-)
I'm inclined towards the wire re-enforcement due to the many dings gaps and thin sections at the flight edges.
I suppose if I had a MIG set up, I could make passes enough to build up just about anything. I have just a AC buzz box to do metal melting, (getting used to it after 30 years ;-) Building on the flight edges is pushing my limits as far as a steady hand goes. (that and the many hollows and thin spots on the flights.
Anyone with ideas on the subject? I could go with strapping instead of wire, but it all needs to bend in a 1 foot diameter helix , and round wire hand bends pretty easily.
