SAME Explorer 11 Turbo 90. Location of "special power lift drain bung" ?
   / SAME Explorer 11 Turbo 90. Location of "special power lift drain bung" ? #1
joe1190
Brisbane, Queensland, Australia
SAME Explorer 11 Turbo 90 DT
Wheel Tractor. SAME Explorer 11 Turbo 90 DT (Dual-Track) 4wd apx. 1995
Wish to change all 52lts of Trany and Hyd oil.
References quote 52lts - but - "6-7lts in the power lift can flow back into gearbox once removed special bung" ???
Anyone know where the special bung is ???
If this bung is on the inside (as references appear to indicate, I hope it is not) it maybe difficult to locate without a few hints.
   / SAME Explorer 11 Turbo 90. Location of "special power lift drain bung" ? #2
Re: SAME Explorer 11 Turbo 90. Location of "special power lift drain bung" ?
If you want to change all of the oil (which I'm about to do on my machine) you will also need to drain the cylinders on you front end loader and/or backhoe, if so equipped.
On my tractor, I'm going to drop the 3-point all the way down, which should empty its cylinder.
Correct and thank you, but apparently there is another bung to drain "6 -7lts from the power lift", does anyone know where that bung is ???
I have tried dealers here and got the ol, I don't know or I don't want-to know.
To be fair, The dealers have changed since this tractor etc
But the info is in service, parts or workshop manuals to which I have none.
I need these books or electronic copies also.
Any help on the manuals appreciated thanks.
LOT LOCATIONS (A54313)
2008 New Holland B110 MFWD Loader Backhoe (A55218)
2008 New Holland...
2019 Fontaine EQ1 Hydraulic Equalizing Spreader (A52377)
2019 Fontaine EQ1...
2008 CHEVROLET C7500 BUCKET TRUCK (A51406)
2008 CHEVROLET...
2006 JLG 2030ES 20ft Electric Scissor Lift (A54811)
2006 JLG 2030ES...
