MF 1742 Not Happy With It
   / MF 1742 Not Happy With It #1
sspc
NORTH BRANCH
massey ferguson
I just bought a new "2017" MF 1742, DL125 Loader, shuttle shift, seven days old and 6 hours on it, I am very disappointed with the quality, I've been moving fill sand around a new garage, as I lifted the loader bucket, "filled" I heard a noise, i opened the hood and noticed the fan blade is hitting the shroud, first problem. Now I went into the pile of sand to fill the bucket in the corner, so i could dump next to the garage wall, The dealer told me I can't do corner lift's because the loader will flex...... Now the quick release bucket will not come off, apparently its flexed from corner lifting? I owned a TC30 for many years and did corner lifts many times. no issues.
   / MF 1742 Not Happy With It #2
I've been saying since the 1700 series came out that their loaders were terrible and I can guarantee you that they switched to smaller buckets because the loaders weren't as good as what they replaced.
So glad I bought a 1643.
   / MF 1742 Not Happy With It #3
Wow, I am sorry. My 1635 has been a great tractor with 350+ hours on it now. I had been thinking about moving up to a little more hp but not so sure now.
   / MF 1742 Not Happy With It #4
Just curious, did you take your bucket off prior to this? My point is, if you did and it worked fine - then maybe the quick release is the issue. And if you didn't - maybe because the unit is brand new - the quick release is just "stuck" by paint or ????
Second question - why would lifting the bucket cause the fan blade to hit the shroud ???
   / MF 1742 Not Happy With It #5
I have no opinion about the DL125 loader compared to the prior - but I can tell you there is a vast improvement in the newer DL95 loader on the Massey GC1700 series - compared to the prior DL100 loader. Dramatic change in weight capacity, heavier built pins and good hydraulic lines positioning.
   / MF 1742 Not Happy With It #6
I have the DL135 loader on my 1758 and it seems strong. Sorry to hear you are having issues.
Maybe bad advice, but have you tried lifting a corner bucket of sand using the opposite corner, maybe to flex things back? Try at your own risk of course !!!
   / MF 1742 Not Happy With It #8
Buy sn Alo loader - much better than the MF loader.
There are two companies that made loaders for Massey. . . . Both are U. S. Made. Ago is one of the two.
Whoever made the dl100 was a fine company but whichever one makes the dl95 loader is an even better builder.
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
FIRESTONE 20.8R42 REAR TIRES WITH WHEELS (WHEELS FITS GENESIS TG-T8000 TRACTORS) (A52748)
FIRESTONE 20.8R42...
2024 JOHN DEERE 8R 280 LOT NUMBER 8 (A53084)
2024 JOHN DEERE 8R...
MARTIN - SET OF 12 COULTER MOUNT MARTIN ROW CLEANERS (A52748)
MARTIN - SET OF 12...
2008 JOHN DEERE 270D LC EXCAVATOR (A51246)
2008 JOHN DEERE...
