1965 MF 135 with Z145 gas engine: Timing mark question
   / 1965 MF 135 with Z145 gas engine: Timing mark question #1
Cedarsnapp
Kenmore, WA
1965 MF 135 with Continental Z145
I want to time my 1965 MF 135 with Z145 gas engine. I removed the timing mark cover, hooked up my timing light to the battery and to the #1 spark plug wire and aimed it into the timing mark hole. I can see the fixed mark on the crankshaft cover, but nothing lights up on the crankshaft. I know with older cars I would put chalk on the crankshaft timing marks so I could see TDC and the before and after TDC marks when the timing light illuminated them. I twisted the distributor by "sound" but it's not perfect and it occasionally misses. Are there TDC marks on the crankshaft? Do they normally need to be chalked to be visible?
The attached photos show the distributor and in the lower right of the engine, the timing mark hole, plus two closer shots of the timing mark hole.
Does anyone have any suggestions how to find and mark the crankshaft timing marks to make them easy to see with the timing light. I haven't timed an engine for decades and may have forgotten an important step. Thanks.
Timing marks and Distributor.JPGTiming marks hole closeup3.JPGTiming marks hole closeup.JPG
   / 1965 MF 135 with Z145 gas engine: Timing mark question #2
I have a MF 135 with the Z-145. Timing marks should be visible in the port.
Yes it helps very much to use white chalk or paint to illuminate the mark.
Rotate the crankshaft until Cylinder 1 is at TDC; the TDC mark should be visible (you may have to inspect closely to see it).
If the TDC mark isn't visible, slowly rotate the crankshaft (using a wrench on the crankshaft pulley bolt) to see if you can locate it. If everything is as it should be, the TDC mark will be there.
Hope this helps.
   / 1965 MF 135 with Z145 gas engine: Timing mark question #3
Hope this helps.
Make sure the #1 cylinder is on the compression stroke when you look for the timing mark!
   / 1965 MF 135 with Z145 gas engine: Timing mark question #4
Jerry:
Keep in mind Cedarsapps' question: "Does anyone have any suggestions how to find and mark the crankshaft timing marks to make them easy to see with the timing light."
In a 4-stroke engine each piston will hit TDC twice in the course of a full combustion cycle, once between the exhaust and intake strokes, and once between compression and combustion. My suggestion was intended to help locate & chalk the timing mark quickly - nothing more.
   / 1965 MF 135 with Z145 gas engine: Timing mark question #5
Jerry:
That's why I reminded the OP that he needs to be on the compression stroke for # 1 because he can also find the timing mark 180 crankshaft degrees away. I guess your point that it's the same timing mark. However if you want to statically time an engine, you need to be on the compression stroke.
   / 1965 MF 135 with Z145 gas engine: Timing mark question #6
Not true: the TDC mark aligns with the timing mark whenever #1 cylinder is at TDC - period. You will never find the TDC mark 180 degrees away from TDC on a correctly built 4-stroke engine.
Your posts make it appear as though you believe that a 4-stroke engine's crankshaft rotates 360 degrees to complete one operating cycle.
   / 1965 MF 135 with Z145 gas engine: Timing mark question #7
Compression stroke as Jerry mentioned. One can plug #1 with a tight wad of paper and as it hit #1 it will blow it out. Timing make should be close to that event.
   / 1965 MF 135 with Z145 gas engine: Timing mark question #8
My bad! I said 180° and I should have said 360° of crankshaft rotation. 180ï° would be distributor shaft rotation.
No I quite well understand the 4stroke cycle. Certainly the timing mark appears at every rotation but since the 4 stroke takes 720° of crankshaft rotation to complete the cycle, the timing mark will appear twice in the cycle. But the ignition is timed to near the top of the compression stroke. As far as ignition timing is concerned, the other part of the cycle is not important. There are plenty of people on these forums that have attempted to time their engines without realizing this and they wonder why they can get them started.
   / 1965 MF 135 with Z145 gas engine: Timing mark question #9
My bad! I said 180ー and I should have said 360ー of crankshaft rotation. 180? would be distributor shaft rotation.
No I quite well understand the 4stroke cycle. Certainly the timing mark appears at every rotation but since the 4 stroke takes 720ー of crankshaft rotation to complete the cycle, the timing mark will appear twice in the cycle. But the ignition is timed to near the top of the compression stroke. As far as ignition timing is concerned, the other part of the cycle is not important. There are plenty of people on these forums that have attempted to time their engines without realizing this and they wonder why they can get them started.
Whew. Finally we agree: if all you are trying to do is locate the crankshaft timing mark (i.e. to put paint or chalk on it), then just put #1 at TDC - the engine stroke doesn't matter.
To illustrate this point let's assume Cedarsnapp's engine has no visible TDC mark and it has to be determined. A TDC mark can be located, completely independent of engine stroke, using a piston stop bolt :
  1. Screw the piston stop into cylinder #1.
  2. Slowly rotate the engine until the piston comes up against the stop.
  3. Mark the crankshaft.
  4. Rotate the engine in the opposite direction until the piston again hits the stop.
  5. Mark the crankshaft.
  6. Exactly halfway between the two marks is the location of the TDC (0) timing mark.
If one is setting ignition timing or valve lash, then obviously TDC and the engine stroke on which they coincide does matter. I assume that most forum members will know that.
   / 1965 MF 135 with Z145 gas engine: Timing mark question #10
Why would there be a difference in the location of the stop point? Back lash? Most of these engines are not initially timed at TDC. They are usually times at 5° to 7° BTDC so you would have to know the flywheel diameter, calculate the arc length from TDC to the initial timing point and mark off the distance to the initial timing point.
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A54313)
2016 WESTERN STAR...
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A53843)
2011 NORAM POWER...
2018 RoGator 1100C (A53473)
2018 RoGator 1100C...
2025 SDLANCH IRGC40 UNUSED Electric Tricycle (A53117)
2025 SDLANCH...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A53473)
Michelin CARGOXBIB...
2019 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4X4 - 72258 miles -Altec AT40G Boom (A53473)
2019 Ford F550...
