Best place to buy 5' box blade
   / Best place to buy 5' box blade #1
dwalk19
Gold Member
Addison, ny
2018 LS XG3140H TLB
Looking to buy a 5' box blade for my XJ2025, I haven't checked the dealer but do have a Tractor Supply close to me any decent places online that aren't a killer with shipping, thanks
   / Best place to buy 5' box blade #2
   / Best place to buy 5' box blade #3
Well, I have no idea what an XJ2025 is, but a good place to start is your local dealer. Otherwise, there are dozens of box blades available thru on-line searching. What you get should depend upon what you expect to do with the box blade. Unless you plan to only use the unit for light duty jobs - I would suggest the heaviest unit your tractor can handle. Weight is your friend when using a box blade. Helps cut deeper, prevent chatter and less likely to be damaged.
I suggest you indicate the brand of tractor you have and the jobs you anticipate doing to receive more specific advice.
   / Best place to buy 5' box blade #4
My local Atwoods store sells a 5' and 6' King Kutter branded BB that costs $580. It seems to be a good medium duty box blade. I have the 5' and it has good thick metal, pretty nice welds, and decent bracing (although I'd like to add a little more ti mine). It also has clevis style 3ph mounts instead of pins.
   / Best place to buy 5' box blade #6
I bought my 5' KK at the local Rural King on a sale for just under $500. It has been great. I like the double blade feature for pulling or pushing.
Yes the tractor is a 2017 LS XJ2025 hydro, with R4 tires which are not filled yet but hopefully soon, i do have the backhoe for weight but obviously it wouldn't be on while using box blade
   / Best place to buy 5' box blade #8
Anything on our website will ship free to YRC Freight in Elmira.
This is an awesome box blade for your tractor and for the dollar: Land Shark 2.1 Compact Box Blade
We'll even paint it EA Yellow to clash less with blue!
Box Blades by EA feature:
US Made cutting edges.
Horseshoe plates of steel on the bottom of the tube behind ripper shanks for durability.
Extra plate of steel on the front leading edge for wear resistance.
Laser cut, A572 steel construction; tabbed and solid welded.
Travis
   / Best place to buy 5' box blade #9
Google Blain's Farm & Fleet in Janesville Wisconsin.
They sell King Kutter box blades, have excellent pricing, and their shipping is VERY cheap.
Is there a benefit to having 5 ripper teeth as opposed to 4,, seems like more teeth the better to break up the ground , although I have mostly clay and rock so either way it's gonna be a tough go
2012 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2012 Ford F-250...
2009 Hyundai Sonata Sedan (A50324)
2009 Hyundai...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2015 F-550 Bucket Truck Gas Engine (A52128)
2015 F-550 Bucket...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
