CalG
Super Member
- Joined
- Sep 29, 2011
- Messages
- 5,841
- Location
- vermont
- Tractor
- Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
When feathering the LIFT of the three point hitch lift cylinder, there is a rather disagreeable region of control lever travel where the hydraulic system is blocked and flow is sent through the pressure relief before the lift cylinder receives any flow. This is evident by the sound emanating through the hydraulic system, the feel at the control lever, the way the engine slows with the load, and the fact that the lift does not move while this is going on.
Further movement of the control lever towards the full lift position does produce the lifting function, but the action is abrupt (Full relief pressure) and very difficult to modulate. The "closed" hydraulic circuit and associated noise and heating is also a bit disconcerting. The lift functions "perfectly" in all other aspects.
I would like a better action and feel to modulate and control the lift, especially when using a box blade or the York rake.
It seems that the lift valve is "out of time", but I can not imagine how that can be. It's like a "break before make" electrical switch.
I realize I may be spoiled with tractors that have both position and draft control. But even the 1950 Fordson does not show such a "dead band" in the 3 pth. lift.
Anyone have any ideas on how to "make it better" ?
TIA
TIA
