Hydraulic jerks
   / Hydraulic jerks #1
musamike
Karoi, Zimbabwe
Ford 7600
I own a refurbished ford 7600 tractor. When I bought it the hydraulic was rising up well. We changed oils both hydraulic engine, to include the filters. For the hydraulic we used about 50l ofspirac 80w 90. Soon after it was not lifting the plough well. It takes time to lift and it does this with jerks. What could be the problem.
   / Hydraulic jerks #2
hydraulic system does NOT use 80w 90 gear lube. It should be hydraulic oil.
   / Hydraulic jerks #5
The problem is the 80w-90.
Get that out of there and install some hydraulic oil.
That souls smooth it back out.
   / Hydraulic jerks #6
Universal hydraulic oil. Most auto parts stock in 5 gal pails, Walmart even carries some.
LOL. I don't know if they have a Walmart in Zimbabwe?
Yes, the 80/90 is your problem. 50L is a lot. Don't waste it. Drain into clean containers and save for use in mower/implement gearboxes or the front (4wd) axle of another tractor if your 7600 is only 2WD. Land Rovers there would use the 80/90 also.
Any hydraulic oil you can get there?
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
2018 Dodge Charger Sedan (A51694)
2018 Dodge Charger...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A52748)
2019 Energreen EVO...
2006 Nissan Xterra 4x4 SUV (A51694)
2006 Nissan Xterra...
2013 MACK GU713 (INOPERABLE) (A52472)
2013 MACK GU713...
