Windmill Help
   / Windmill Help #1
jpalex
Carmichael
Gibson D
NewBe here. Kind of belong, have a Gibson D tractor.
Just acquired a Flint and Walling windmill and would like to talk to someone who's a lot more in tune than I with them at the moment.
Any direction you can give me?
Thank you.
JPALEX
   / Windmill Help #2
:welcome:
To the TBN forum. You came to the right place as I am sure someone will be able to help.
   / Windmill Help #3
I've rebuilt the crank [machined the rods and flywheel to hold ball bearings] of an "ironman" waterpump windmill, and had some experience with small power generating ones too.
What do you need to know?
   / Windmill Help #4
I have not been on this board for some time so I do not know what is happening now but there are a lot of knowledgable people on this board,
VintageWindmillParts.com Index page
I know some about aermotor mills, and have rebuilt a number of them, but I have a few F&W parts (I think) a head and some blades, but besides saving them I have not done much with them, was going to put on short wood towers and display them but that is yet to come,
   / Windmill Help #5
:welcome:
Welcome to the forum! I'm going to move this post over to our rural living section. :sunrise:
   / Windmill Help #6
I have a F&W Star 26, 2 F&W Star 37s, a Star 24, and 3 Baker Heller-Allers, All up and running in the wind.
   / Windmill Help #7
I rebuilt a Star 24 a few years back. New roller bearings, drilled and tapped the shaft for a huge washer so the wheel won't fall off...a common problem after a rebuild.
   / Windmill Help #8
That's remarkable. Same thing happened to one of my 37's and the 26. If you drill the drive shaft to pin the wheel hub, the shaft will break from fatigue. I drilled it axially and drove in a cap bolt.
   / Windmill Help #9
Thank you.
JPALEX
For some reason, this didn't load this morning.
Lenny
   / Windmill Help #10
Well, I am one of those that drilled through the drive shaft, and indeed the shaft did break. Thinking of having a new shaft made. Most of the dimensions are obvious, but the front part of the shaft that is inside the wheel is badly worn.
Question what is the original diameter of the driveshaft inside the wheel? Is it the same as the rest (about 1 1/8")
Thanks
Jheroen
2023 MAXEY G8X 26FT TILT BED GOOSENECK TRAILER (A54607)
2023 MAXEY G8X...
2015 INTERNATIONAL LF687 (A53843)
2015 INTERNATIONAL...
Pair of New 700/40-225 Alliance Tires with Rims (A55301)
Pair of New...
40ft Sea Container (A52384)
40ft Sea Container...
2013 Mack GU813 T/A Concrete Mixer Truck (A52377)
2013 Mack GU813...
UNUSED LANDHONOR AD-12-23C HYD AUGER (A54757)
UNUSED LANDHONOR...
