How to locate outlet starting from breaker panel?
   / How to locate outlet starting from breaker panel? #11
a lamp or fan plugged into outlet and then switch off breakers till you find it.
Use a radio turned up loud. Then you can tell while still at the breaker panel.
Bruce
Bruce,
Thanks for the suggestion. I can't start flipping breakers off though because I have computers that need to stay running.
Turns out the wire to the "exerciser" breaker was a red wire...traced it to the romex coming in to the panel and I found out its a 12/3 with ground. The black wire fro the romex goes to another 20 amp breaker. So this is a multi branch circuit where the 2 circuits share a neutral. The breaker for the black wire goes to our bathroom. Which means the breaker on the red wire, for which I'm trying to find the outlet, has to be really close to our bathroom. I'm guessing its an outlet in our closet. I have a hunch I know what outlet and I'll check after work. If its not the outlet that I think it is, then I'm going to use the tone generator to find it. Shouldn't take more then about 10 minutes.
Discovering it was a multi -branch circuit really narrowed down where the outlet could be!
   / How to locate outlet starting from breaker panel? #13
why don't you get a piggy back (tandem single pole breaker) and add the wire for an extra circuit?
You can't use them in all panels. It depends on the type of bus bar in the panel. My panel won't accept them.
   / How to locate outlet starting from breaker panel? #15
Just a thought didn't know you had a panel Not UL listed for a tandem breaker.
   / How to locate outlet starting from breaker panel? #16
Some of the tools your looking at comes with a adapter so to speak. Plug in to alligator clips converter. Have to be extra careful hooking them up. Also be sure the tracing device your using can be used on active circuits with voltage in them. Have to read the instructions before you purchase most likely.
   / How to locate outlet starting from breaker panel? #17
Bruce
Ditto. What I've done for years.
   / How to locate outlet starting from breaker panel? #18
Bruce,
You should know that 2 circuits that share the neutral are required to have the breaker handles tied together. Example: a two pole breaker with a common handle. Having two separate breakers apart from each other where the handles can't be tied together is a code violation.
   / How to locate outlet starting from breaker panel? #19
I'm lost.
Everyone suggesting a radio or similar and flipping breakers....yea that helps you figure out what breaker the outlet is tied to.....but isn't his situation just the opposite.
He knows the breaker. Just wants to find the outlet.
Seems pretty simple to me. Turn that ONE breaker off. Walk around the house with a lamp, fan, whatever and see what outlet(s) no longer work
   / How to locate outlet starting from breaker panel? #20
Even easier use a non contact current tester.
UNUSED LANDHONOR LHR-LB9510 GAS LEAF BLOWER (A54757)
UNUSED LANDHONOR...
16ft T/A Flatbed Trailer (A53424)
16ft T/A Flatbed...
2016 Chevrolet Malibu Sedan (A53424)
2016 Chevrolet...
2017 Ford Explorer SUV (A53424)
2017 Ford Explorer...
2022 PETERBILT 579 TANDEM AXLE SLEEPER (A54607)
2022 PETERBILT 579...
2017 E-Z Beever M12R Towable Brush Chipper (A50322)
2017 E-Z Beever...
