How to locate outlet starting from breaker panel?
   / How to locate outlet starting from breaker panel? #21
You should know that 2 circuits that share the neutral are required to have the breaker handles tied together. Example: a two pole breaker with a common handle. Having two separate breakers apart from each other where the handles can't be tied together is a code violation.
Wish the people that wired my house in Rapid City knew that. I had a circuit where each the top and bottom outlet in each duplex receptacle was on a separate circuit. I needed to do some work on one outlet and got bit because it never occurred to me that someone would wire that way. I guess they got a good deal on some 12/3 wire.
Doug in SW IA
   / How to locate outlet starting from breaker panel? #22
Doug in SW IA
That can be done even without 12-3 or a mwbc.
That's why you test BOTH sides of a duplex recep. before you work it. And even if you didn't, the connector tab that ties the terminals together being missing should be clue #1
   / How to locate outlet starting from breaker panel? #23
Doug in SW IA
That's typical for living room wiring, you'll probably find that a light switch controls one side. Used for lamps and lighting.
   / How to locate outlet starting from breaker panel? #24
In this case they were not controlled by a switch, both sides were hot all the time. Test both sides, connector tab, hindsight is 20/20.
Doug in SW IA
2019 Ford F-350 4x4 Crew Cab Auto Crane EHC-4 4,000lb 2 Ton Mechanics Crane Service Truck (A53422)
2019 Ford F-350...
2024 LS MT242E MFWD Compact Utility Tractor with LL3003 Front Loader (A55302)
2024 LS MT242E...
2023 CATERPILLAR 259D3 SKID STEER (A52705)
2023 CATERPILLAR...
Ammco Brake Machine (A53424)
Ammco Brake...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2017 FREIGHTLINER...
