kubota l3250 new toy, restoration, 3 point linkage fault
   / kubota l3250 new toy, restoration, 3 point linkage fault #11
Here is a parts manual. Look under control valve and safety valve.
  • L3250DT.pdf
   / kubota l3250 new toy, restoration, 3 point linkage fault #12
For the 4x4, page 166, PROPELLER SHAFT... or it could be internal, the part that engages that shaft.
For the 3ph, page 204, CONTROL VALVE [COMPONENT PARTS] This could be a bit tricky, are you mechanically incline?
many thanks I have just discovered I can power up link arms through loader sp valve but have to lower them with position control lever I suspect the problem may be with pos control valve
many thanks I suspect the problem is with the control valve as i have just discovered link arms can be powered up through loader spool valve but must be lowered with control valve . I have dabbled with mechanicals all my life landrovers etc but tractor hydraulics are new to me regards neil
my efforts with the tractor are limited to when I have the time (the same with my IT skills ha ha ) however I have just discovered I can power up the link arms through the loader sp valve but have to lower them with the position control I therefore think the problem is with the p c v would you agree ? kind regards neil
   / kubota l3250 new toy, restoration, 3 point linkage fault #16
...the loader sp valve...
Neil, what do you mean by this? What is the "sp" valve?
Something definitely doesn't seem right - Do you have a photo of the valves in question or the area in question, that you can post here?
(Just in case you don't know how to post a photo... Also it depends on how you reply to the thread, there is an area below where you hit the "Submit Reply " Look for "Manage Attachments"... if you need more help with that, let us know...)
hi there by sp valve I was referring to the loader spool valve (only one lever) I have now removed the top cover from the back end and carefully dismantled the pos control valve but cant see any obvious problem so I am now a little stumped
I have now dismantled pos control valve beneath top cover but cant see any obvious problem and so now am a bit stumped
   / kubota l3250 new toy, restoration, 3 point linkage fault #19
You said that "...however I have just discovered I can power up the link arms through the loader sp valve..."
So, to make the arms go up, you work the loader and the three point linkage or just working the loader will make the arms go up?
Normally the loader Spool/Valve; the plumbing is High pressure goes into the loader valve labeled "P"... stands for pump (high pressure input) and "T" stands for tank (low pressure return to reservoir) There is also, "PB" for Pressure Beyond (high pressure to power your 3 point hitch). There is also 4 port for the lift and curl, those should not be the problem. Can you confirm that the loader valve is plumbed correctly?
   / kubota l3250 new toy, restoration, 3 point linkage fault #20
Teg I'm with you. His work ports return is feeding the 3pt. and the PB is going right to the sump.
2009 Freightliner M2 106 Ambulance (A51692)
2009 Freightliner...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
Road Drag (A50514)
Road Drag (A50514)
2023 JOHN DEERE 30G EXCAVATOR (A51242)
2023 JOHN DEERE...
2004 Honda Pilot SUV (A50324)
2004 Honda Pilot...
2012 International ProStar Sleeper Cab Truck Tractor (A51692)
2012 International...
