Rara Avis
CO2, not dry chemical.
You don't want to try to restart the engine until the injection pump is repaired.
A runaway usually won't hurt an na engine because the volumetric efficiency nose dives at high speeds and friction overcomes airflow limited power.
A turbo engine is another story.
Correct...especially the turbos on John Deeres from India...
from the operator's manual...
Engines with Turbocharger
IMPORTANT: If the engine stalls when in operation, restart it IMMEDIATELY. This will prevent the turbocharger from overheating.
Most damage to the turbocharger is caused by not following the correct procedure when starting and shutting off the engine. After starting and before shutting off, idle the engine without load for at least 30 seconds.
But in a run-away state...I'd rather sacrifice the turbo than the whole engine...
