3910 lift arms
   / 3910 lift arms #1
Rascalsweet
New Tazewell, TN
1988 ford 3910
I have a 3910 2wd, we've managed to break a lift arm over years carrying hay bails. The bails weight is causes the arms to bend side to side and one finally broke at point where the sway chains attach. When i do a parts search for lift arms it gives me the arm that are attached to shaft up by the seat that actually do the lifting, I need to ones that attach to attachment and tractors it's self.
1. What is that arm called and where can I buy quality one at a decent price?
2. Can I convert to a 3930 system, and would it really be stronger?
Thank you
   / 3910 lift arms #2
Draught Link/Arm (English). Draft Link/Arm (Ameriglish).
How big are these hay bales?:shocked:
   / 3910 lift arms #3
Look in the New Holland parts book online for the 3910 under the HYDRAULICS section. Then find the following tab:
(05D04) - HYDRAULIC LIFT LINKAGE(81/)-2810,2910,3910,4610,4110,3910N,4110N,4610N; (82/84)-3910V,4110V,4610V.
Converting to the 3930 system would be very expensive, although stronger. But my question is why are arms twisting? Can the mount for the lift be modified to allow the arms to lift straighter or prevent twisting?
   / 3910 lift arms
Never weighed them, 5x6 is what started them flexing, the guy that now does our baling uses 5x4. I still have to back up the hill to keep the front in down and the bale off the ground. Any how more than is healthy for the tractor I'm sure. I finished it off bush hogging, I got a good deal on heavy duty woods 5 foot I think.
   / 3910 lift arms
It's more side to side motion than twisting, I need heavier stay arms too. I think my factory one got picked up for scrap steel, long story, one i got from coop are flimsy.
thank you both
   / 3910 lift arms #6
The PO of my 2120 welded I think 1/2 x 1/2 bar stock to the bottom of my arms. He may have had the trouble you describe. Seems to work fine.
Jim
2009 PARKER 25 T/A GOOSENECK TRAILER (A52472)
2009 PARKER 25 T/A...
2015 FREIGHTLINER CASCADIA (A52472)
2015 FREIGHTLINER...
2004 Hydraulic Breaker Excavator Attachment (A52377)
2004 Hydraulic...
HARDEE RD72M LOT NUMBER 158 (A53084)
HARDEE RD72M LOT...
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
2019 TRITON TRAILER ALLMAND MAXI LITE 45 GENERATOR (A52472)
2019 TRITON...
