John Deere 212 throwing deck drive belt
   / John Deere 212 throwing deck drive belt #1
chazdo2
auburn new york
walk behing power drive 21
Got the right belt will not go on. I double checked the number its a JD belt number M44121. does any body know the proper way to install the belt? I found the arm tensioner with the two pulleys on it was bent some. I re bent it to what I think it should be. Does anybody have a good picture of the mower drive belt tensioner so I can see if I bent it back correctly?
   / John Deere 212 throwing deck drive belt #3
Same 'member' asking questions on same issue... This is becoming tedious.
PLEASE stop opening a new thread for a new query on the same issue Chaz. You need to read :shocked: the replies you already have for the posts you already made.
And the belt you have is wrong. It is the secondary drive off the variator clutch for the Trans. :2cents:
What size deck do you have???
New/Unused 7ft Stainless Steel Work Bench with 20 Drawers (A51573)
New/Unused 7ft...
(5) 55 GALLON POLY DRUMS (A51248)
(5) 55 GALLON POLY...
UNUSED TOPCAT SSSCR72-72" HYD SOIL CONDITIONER (A51248)
UNUSED TOPCAT...
MARS AIR DOORS TAN BANK (A51248)
MARS AIR DOORS TAN...
2022 Wacker Neuson SM100 Mini Skid Steer (A53472)
2022 Wacker Neuson...
2023 CATERPILLAR 259D3 SKID STEER (A51246)
2023 CATERPILLAR...
