Cummins (or other) oil pump priming during assembly
   / Cummins (or other) oil pump priming during assembly
Jelly sounds like it could work, it certainly won't leak out. Cranking to oil presure before enabling injection is good too although it might require some footwork. It should actually be THE way to start ALL THE TIME. I'm going to give this a try on operating engines (a Deutz F4L912 and a another Cummins 5.9). On the Deutz 4-holer I can keep the he power lever at cutoff until I see oil, on the 5.9 I have an electrical shutoff solenoid that isn't used, I could wire that up or I could just haul the shutoff cable until I see oil.
For the very first start I'll pack some jelly in there anyway, it's cheap insurance. I could be trying a restart in a week or two.
   / Cummins (or other) oil pump priming during assembly #12
The petroleum jelly method was called for in the book when I opened up the bottom end of an Oldsmobile diesel for my dad. And of course get the oil filter to absorb as much as you can before installing, that can save a few seconds of dry running.
Agree that it would be nice to have a pre-oiler that could run every time; didn't I read somewhere that about 80% of wear occurs at startup?
I vaguely remember something along those lines too, I'm seriously planning to deploy the starter into that role as far as line ops go. It's a bit like airplane accidents, most of them happen close to ground :)
I can second the petroleum jelly method, did that and got good 35psi pressure cranking before starting an empty oil pump on a fresh build.
2005 GMC Sierra Pickup Truck, VIN # 2GTEK13T851399344 (A51572)
2005 GMC Sierra...
JOHN DEERE 54D LOT NUMBER 160 (A53084)
JOHN DEERE 54D LOT...
2008 New Holland B110 MFWD Loader Backhoe (A53472)
2008 New Holland...
Pallet of (4) 10 Lug Misc Wheels (A51573)
Pallet of (4) 10...
Loflin 72in Quick Attach Skid Steer Grapple (A51573)
Loflin 72in Quick...
2017 TAKEUCHI TB240 EXCAVATOR (A51246)
2017 TAKEUCHI...
