1979-1982 Ford Courier or Mazda Cam Gear Nut
   / 1979-1982 Ford Courier or Mazda Cam Gear Nut #1
AchingBack
Southern Oregon
Mahindra 2615HST
Somehow the nut holding my cam gear in place came off and fell into the oil pan. In the process the timing chain also broke. It is a very special hardened steel nut. It is chewed up and may be too unreliable to use.
I'm hoping by the grace of God, someone on here has one or knows where I can obtain such a rare part. If I can't find one, my truck will be worthless as is. I'll post a pic. after I get the nut from the mechanic.
Thanks,
Bob
P.S. Sorry I neglected to say the parts I need are for the 2.0 Japanese engine, not a 2.3
   / 1979-1982 Ford Courier or Mazda Cam Gear Nut #2
I had a friend that was a bit too enthusiastic with the impact gun and broke the nut and treads off the end of the cam. So I just told him to drill and tap the end of the cam and use a bolt and washer instead of a nut. A bit of loctite on the treads and problem solved. This would work for you too.
Thank you. I'll consider the idea if necessary. Do you think it is possible to do this with the cam installed? I'd hate to remove it. I guess the big concern is protecting from metal filings falling into the engine. It shouldn't be a problem, though.
   / 1979-1982 Ford Courier or Mazda Cam Gear Nut #4
Yes I think it would be possible to drill with the cam installed. Just stuff the hole with rags and lay a few magnets underneath.
Would it be possible to take the old nut to a machine shop and either have them clean it up or make you a new one?
I see the year and make in the header. Maybe someone has one laying around. I pretty sure I could get one from a wrecker that lives not too far from me.
A friend owns a machine shop. If necessary, I'll ask him about making one. In my area there is only one wrecking yard, and currently, no Couriers.
My engine is the 2.0 Japanese made.
   / 1979-1982 Ford Courier or Mazda Cam Gear Nut #6
Just have one made and be done with it. I have just bought a quality not and then drilled and tapped it to make something that works in hard to find stuff in the past.
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
2020 CATERPILLAR 289D3 SKID STEER (A51242)
2020 CATERPILLAR...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
2019 Harley Davidson (A50324)
2019 Harley...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A48082)
2016 Toro...
