How do I slow down side to side motion of HLA2000 angle plow
   / How do I slow down side to side motion of HLA2000 angle plow
The crossover on a DA cylinder will only work one direction. That's when the cylinder is extending.
And even then, the oil that is "crossing over" isn't enough to fill the void created by the cylinder extending. So you are introducing air into the system. Could be your problem..
Why would it relieve in only one direction? That makes no sense. I thought the purpose of that relief valve was to allow oil to pass from one side to another in the event you hit something hard (a rock or tree for example), with one side of the plow, creating a pressure spike. It should work when the control valve is not even open. Am I missing something?
   / How do I slow down side to side motion of HLA2000 angle plow #12
Yes.
Base side of cylinder holds more oil than rod side.
So when you try to compress cylinder, you are trying to move MORE oil out of the base end of the cylinder than there is room for on the rod side.
With the control valve centered so no oil can pass, there is a closed system. You CANNOT shove a cylinder rod into that closed system without oil leaving somehow.
Crossover valves we're intended to be used on a PAIR of cylinders, a double rod cylinder, or a hydraulic motor with high inertial load.
They were never mentioned to work on a single double acting cylinder. So I cannot answer why people and manufactures continue to mis-apply it's use.....oh wait, yes I can. They don't understand hydraulics
The manufacturer recognizes that it is not the most effective solution, but better than nothing. Furthermore, if one typically plows pushing snow to the right (as if driving on the right side of the road...I always do), the likelihood of hitting something is far greater on that side, hitting something in the ditch, a guard rail, sign or whatever. Because the base end of the cylinder is on the right side of the tractor and the rod end is on the left, when hitting such an object, the crossover should work fine, as it's dumping less oil from the rod end of the cylinder to the base end.
You are most correct though that if you hit something on the left side of the plow, not much oil is going to pass, (unless the piston seals are shot, lol).
   / How do I slow down side to side motion of HLA2000 angle plow #14
Nope. That's wrong. Even if Piston seals are shot, no oil is gonna transfer. Simply not enough room. You could remove the Piston and seals all together.... You are NOT gonna shove a cylinder rod down into the cylinder (retract) without oil LEAVING the cylinder.
On a single DA cylinder, which port is "OUT" :confused3:
They both are, at one time or another. When the rod is extending, the rod port will "meter out" through the flow control valve. When the rod retracts, there will be full flow the other way through that port, and metered flow out the other port. All I have to do is end for end the flow controls.
   / How do I slow down side to side motion of HLA2000 angle plow #17
Thats typical of a pneumatic flow control, not typical of a hydraulic flow control.
Well, I'm not using pneumatic flow controls; I'm using Parker hydraulic flows. These work exactly as described; they have a ball check and needle valve built into the block. I'll let you know how well it works once I reverse them.
2018 HINO CONVENTIONAL TYPE TRUCK (A52472)
2018 HINO...
12 ft Shipping Container (A55973)
12 ft Shipping...
2012 Chevrolet Van (A55973)
2012 Chevrolet Van...
2007 International 4300 (A53314)
2007 International...
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
2015 Ford Transit Cargo Van (A54814)
2015 Ford Transit...
