2310 transmission/rearend fluid level check
   / 2310 transmission/rearend fluid level check #1
Mouse77
Mena, Arkansas
Ford NAA, Ford 2000, Ford 1710, Mahindra 2310
Talked to an ex-dealer locally and he didn't know on 2310 but a 2810 in his shop had a dipstick. Mine does not have dipstick just the plastic cap, dealer could tell me how much to put back in on a drain and refill but where level should be. Anybody have a 2310 that knows?
   / 2310 transmission/rearend fluid level check #2
There is a site glass ( level window) on the rear of the tractor near the PTO shaft, fill it until the level is in the middle of the window.
   / 2310 transmission/rearend fluid level check #3
That's all well and good, but the fluid I put in is sooooo clean that if you go over the window you'd think there wasn't enough! I wish they'd dye it purple or something.
   / 2310 transmission/rearend fluid level check #4
Same thing using the dipstick on my 4110, no hashmarks or anything and can't see the fluid on the stick. I have to use a piece of paper and carefully butt dipstick up against it to see where the level is.
Thanks all for the input. That area was covered in mud so didn't see it. Thanks again.
   / 2310 transmission/rearend fluid level check #6
You can purchase a Red-coloured dye for hydraulic/trans oil - from your 'Toro' dealer. It is used in all their machines on Golf Courses. Small bottles, 'cos a little goes a long way...
   / 2310 transmission/rearend fluid level check #7
Yep, and there is hydraulic dye (red) available from John Deere; I'm not pushing JD, all colour tractor owners use it. Small bottle and only a few drops.
Do NOT use food dye! It will bugger things up.
   / 2310 transmission/rearend fluid level check #9
Mahindra's Hydraulic fluid that we sell at our place is dyed purple
1989 Freightliner FLD120 (NEW CAT 3406A, NEW REAR ENDS, CLUTCH) (A50397)
1989 Freightliner...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52141)
2019 INTERNATIONAL...
6' Skid Steer Skeleton Bucket (A50515)
6' Skid Steer...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
UNUSED CFG Industrial QK18R Mini Excavator (A47384)
UNUSED CFG...
2021 JOHN DEERE 410E-II 6X6 OFF ROAD DUMP TRUCK (A51242)
2021 JOHN DEERE...
