Bx2200 axle pivot leak
   / Bx2200 axle pivot leak #1
johann
bx2200
Has anybody changed the seals on the pivot pin that holds front axle on? It looks pretty straight forward, but like anything when it comes to wrenching on things there can always be surprises and tricks to make the job easier....any advise?
   / Bx2200 axle pivot leak #2
Do you mean bevel case seal or where the axle pivots in the center where it attaches to the frame?
Where the axle attaches to the frame and pivots on a pin that runs through.
   / Bx2200 axle pivot leak #4
It isn't a bad job to do.
I do recommend getting a new pin (AKA Shaft Center): K2561-15133 --- SHAFT CENTER
do you have to disconnect the hydraulic steering lines when you drop axle/differential
   / Bx2200 axle pivot leak #6
I did. It's not hard. I treat hydraulic hoses like I do brake lines. You don't want to chance having something hanging off them yanking up the hose.
2011 Kubota R520S 4WD Articulated Wheel Loader (A51691)
2011 Kubota R520S...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2015 FORD F350 SERVICE / MECHANICS TRUCK (A52576)
2015 FORD F350...
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A53472)
2016 Kawasaki 70...
2022 Third Coast Reversible Plate Compactor (A51573)
2022 Third Coast...
