Plumbing - 3/8 PEX vs 1/2" Pex - is 3/8 dead?
   / Plumbing - 3/8 PEX vs 1/2" Pex - is 3/8 dead? #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
I'm getting ready to "replumb" the "apartment" in my shop. It's got 1 kitchen sink, 1 "water closet" (seems people don't use "toilet" anymore) 1 bathroom sink and 1 shower/bath.
Based on my readings I was going to use 3/8" PEX for some, 1/2" pex for others, off manifolds (1 for hot, 1 for cold). But looking at Lowes they don't sell 3/8 PEX in lengths.
Main reason to use 3/8 was smaller holes and bends.
Is 3/8 PEX ancient history?
   / Plumbing - 3/8 PEX vs 1/2" Pex - is 3/8 dead? #2
Yes, use 1/2" minimum, you actually don't get a true 1/2" ID with pex as compared to copper, but you can run higher velocities and you don't have any fitting losses if you home run everything from the manifold.
   / Plumbing - 3/8 PEX vs 1/2" Pex - is 3/8 dead? #3
Stick with what is plenteous and with fewer transitions. Easier.
Do you have a 1 handed ring crimper and do they use the same copper bands as the 2 handed crimper? I have a 2 handed but is very unwieldy in tight spaces and was looking for something compact..
   / Plumbing - 3/8 PEX vs 1/2" Pex - is 3/8 dead? #4
Even if you could find 3/8 locally, it would probably be more expensive as its not as popular.
I dont do bends on pex either. I know some do, but I use the 90's and crimps as it makes a cleaner install
Since I'm going to be able to expose the manifold and most fittings I was thinking of going with a 6 port PEX Plumbing Manifold 3/4 Male 1/2 Ball Valve with PUSH FIT closed end and similar for the hot with push-fits at the faucets. I have not gotten into the other myriad different "standards" of connecting PEX.
   / Plumbing - 3/8 PEX vs 1/2" Pex - is 3/8 dead? #6
A single bathroom for one person can use a manifold but I avoid them. I run 3/4 to each bathroom and certainly through the water heater (if this is going to have one).
As stated 1/2" min. 3/8" is for your drinking water faucet.
   / Plumbing - 3/8 PEX vs 1/2" Pex - is 3/8 dead? #7
I tried to find a couple hundred feet of 3/8" a few years ago to thaw an underground water line. It had to be special ordered. Of course this is Canada. Fast becoming a third world country.
   / Plumbing - 3/8 PEX vs 1/2" Pex - is 3/8 dead? #8
I have never used anything smaller than 1/2. Best I remember. 1/2 pex would be 3/8 id. 3/8 pex would be 1/4 id
ASCO Transfer Switch (A52377)
ASCO Transfer...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A55301)
Michelin CARGOXBIB...
2000 Safari C-Series 425 40ft Panther Motorhome (A52377)
2000 Safari...
UNUSED EINGP F10 - 10' WROUGHT IRON SITE FENCE (A54757)
UNUSED EINGP F10 -...
Honda EU3000is Gasoline Companion Inverter Generators (A51691)
Honda EU3000is...
