New Member -- Kubota B7500 250hr so far -- question on exhaust.
   / New Member -- Kubota B7500 250hr so far -- question on exhaust. #1
Ron G
Asheville, NC
Kubota B7500
Hi, My B7500 is an HST. Front Loader, 5' blade, carry-all, Goosen Chipper/Shredder. 3 1/5 acres, very steep. Tractor primarily for hauling, timber felling and winching, grading roads and terraces, and plowing snow for neighborhood along 1.5 mile drive.
I'm far enough away from the dealer to make self-maintenance the only real option. Found routine stuff easy; but, more than once I'e been fooled by the starting routine with all it's safety switches, clutch adjustments. Jumpered the seat safety switch. Seemed redundant. Occasionally, won't start; raise hood, poke around, close it. She starts.
Two questions: The exhaust location really makes cleanliness impossible. Can I put an extension on it to redirect somewhere? Is there an easy way to clean the deposits?
Ron G
   / New Member -- Kubota B7500 250hr so far -- question on exhaust. #2
:welcome:
Welcome to the forum!
I'm going to move this thread over to our Kubota section to see if we can find you some advice.
   / New Member -- Kubota B7500 250hr so far -- question on exhaust. #3
Ron G
I don't know of any really good way to clean the deposits. I use diesel fuel, a rag, and then soap.
But I have extended the exhaust on several small tractors by rotating the muffler so that the outlet was vertical and then adding several feet vertically (along with a rain cap) so as to get the exhaust up away from the tractor. Vertical section should be slightly larger diameter (slip fit) and light weight tubing. Sometimes electrical conduit is perfect.
rScotty
New/Unused CFG Industrial H15R Mini Excavator (A51573)
New/Unused CFG...
2020 CAT 239D3 Skid Steer (A51573)
2020 CAT 239D3...
(1) 330 GALLON POLY TOTE W/ CAGE (A51248)
(1) 330 GALLON...
UNUSED WOLVERINE TQH-26-02C CLASS II 3 PT HITCH (A51248)
UNUSED WOLVERINE...
(1) 275 Gallons of Aluminum Brightener (A51573)
(1) 275 Gallons of...
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
