Has anybody here turned up their yanmar 3cyl diesel?
   / Has anybody here turned up their yanmar 3cyl diesel? #1
expeditionnw
portland or
ASV MD 70
I have a yanmar 3TNV82A-D engine that is rated for about 30hp currently. It was originally sitting in a 2007 john deere F1400 4x4 mower. I have a project in the works that Id like to power with this motor. It will be replacing a 40hp gas motor. I suspect it will likely make the torque of the gas motor, but i sure would like to get some more suds out of it! anyone bombed one of these little guys?
   / Has anybody here turned up their yanmar 3cyl diesel? #2
I would put it in it's final place and test it before doing a single thing to it. A horsepower is a horsepower, of course, but the 40 hp gas engine it's replacing likely didn't have the torque curve (specifically, area under the curve) of the Yanmar. If you are in doubt as to the power it may be best to start with a different engine.
Absolutely agree Cincy. And that is likely what i will do. Just collecting notes ahead of time.
   / Has anybody here turned up their yanmar 3cyl diesel? #4
You could probably swap that Yanmar for a small block Chevy. That should work.
I could do a lot of things... That being probably the least likely option.
   / Has anybody here turned up their yanmar 3cyl diesel? #6
I would take a look at the rpm's of both engines. The original gas engine probably has a lot higher rpm curve, which may be geared for a faster rpm motor. Top end speeds in all gears may take a hit, probably by almost a third or more.
David from jax
2006 KOMATSU  D41P-6  CRAWLER TRACTOR (A52576)
2006 KOMATSU...
Electric Concrete Mixer (A51573)
Electric Concrete...
2016 JOHN DEERE R4038 LOT NUMBER 195 (A53084)
2016 JOHN DEERE...
CHALLENGER MT525B TRACTOR (A51247)
CHALLENGER MT525B...
New/Unused Quick Attach Post Driver (A51573)
New/Unused Quick...
Plasmarc PM150 Plasma Cutter (A51691)
Plasmarc PM150...
