Father in Law wants a Handheld Gas powered earth auger
   / Father in Law wants a Handheld Gas powered earth auger #11
I'm wondering about the 320 rpm on the description list. The 45 pounds of torque surely does not seem like much.
Fifty some years ago I had my hands on one. Not a pleasant experience.
   / Father in Law wants a Handheld Gas powered earth auger #12
I'd venture that none of the guys knocking the Horror Freight unit have ever actually used one. I have. and in rocky soil - I live in the Sierra Nevada foothills. My soil is decomposed granite, decomposing granite, and solid granite, with lots of oak trees. My neighbor and I have dug 12" holes 3 feet deep with a 3pt PTO auger and two tractors - one to drill, one to push down with the FEL. The soil here is tough. The Predator 2HP unit works great.
If he gets one, PAY ATTENTION TO THE INSTRUCTIONS. It's a 2-cycle motor, with a very high oil content in the mix. They also recommend gas stabilizer. I bought a new gas can with a push-button spout exclusively for this unit. Check the air filter screw, as it will vibrate out. I replaced mine with a longer screw.
It starts easily, runs strong, and does not spew excess oil in the exhaust. The throttle is spring loaded, so if it sticks and spins, it will go to idle. I stuck it bad enough to shut it down, remove the powerhead, and unscrew it with a wrench - it had caught a large deep root off-center, and screwed past it instead of chewing through it. It will bring 3" rocks to the surface and spit them out. The 6" auger is great for 4x4s, and it's easy to drill clusters if you need bigger. There are replacement augers, but no other sizes. It digs 22-24" deep, and will leave loose dirt in the bottom of the hole. I just scoop it out.
I've drilled a dozen or so vertical holes full depth, one at a steep angle to get a sprinkler line under an obstruction, and used it quite a bit to start or end trencher runs. I have a bad shoulder, but have no trouble using this unit. It has exceeded my expectations in every way.
I've beat up the auger a bit, but it still works. When it doesn't, I'll replace it for $50, and try repairing the original - I weld, too, but not with Chicago Electric stuff.
   / Father in Law wants a Handheld Gas powered earth auger #13
I frequently see the Harbor Freight Gas Powered Earth Auger on-sale for $159.99.
I have the Land Pride PD10 with the 9" auger on my BX2370.
It's rated @ 30", but I feel like that's generous.
I have been toying with the idea of the 6" Harbor Frieght with an extension to get me down around 36" when needed.
(seems like it would be easier than trying to mess with a 7" or 14" auger extension on the PD10 -- maybe not?)
   / Father in Law wants a Handheld Gas powered earth auger #14
Personally I would prefer a ton or two of tractor attached to a post hole digger rather than my 64 year old somewhat worn carcass attached to it. But that's just my personal preference.
   / Father in Law wants a Handheld Gas powered earth auger #15
I too, have the HF auger. I have used it to put in at least 60 posts for a wood fence. It works great w/ a 6" auger. It is a LOT of work! Usually letting you know how hard it beat you up the next morning when you wake up..... When I bought it, I did not have a 3 point. Now that I have a tractor and a PHD, I'll probably never use the hand held again!
   / Father in Law wants a Handheld Gas powered earth auger #16
I have one of the HF ones. Id gladly sell it it was only used twice and with me and my arthritis and tendonitous I found its a torture device from ****.
I bought it when I needed to dig a few holes on a property but my tow vehicle was broken so couldnt take the tractor and 3 pt auger. Let him get one if hes hard headed. He wont use it much.
   / Father in Law wants a Handheld Gas powered earth auger #17
I have a Thunderbay 8" one from Lowes that seems to work out well. The advantage of these are the locations that you can use vs a 3 point model, plus you can hog out the hole.
   / Father in Law wants a Handheld Gas powered earth auger #18
If he's spending his own money I say, cut the man some slack. We old men don't appreciate being told what to do.
   / Father in Law wants a Handheld Gas powered earth auger #19
I borrowed an Earthquake 6" gas powered earth auger when I was 45 years old. I wanted to plant about a dozen trees around the house. It was early fall and the ground was so hard, the point wouldn't start a hole. That thing let me know who's boss just carrying it from hole to hole to see if it would dig. It never dug a hole. I did get 2 trees planted that fall but I had to use a pick and spade to get through the first 4 inches of soil.
   / Father in Law wants a Handheld Gas powered earth auger #20
Smart do not need to be told- Dumb do not listen. Stay away from this mistake. In no way get tied into giving a opinion. Danger.
BOLTS, NUTS & WASHERS W/BIN (A55745)
BOLTS, NUTS &...
John Deere Gator Utility Cart (A50324)
John Deere Gator...
2018 John Deere 640FD Draper Head (A53485)
2018 John Deere...
2019 TURNKEY DATA VAN (A55745)
2019 TURNKEY DATA...
2007 Saturn Sky Convertible Coupe (A55853)
2007 Saturn Sky...
2003 Big Tex 10PI...
