Mowing Air ride seat on a zero turn?
   / Air ride seat on a zero turn? #1
mikester
Elite Member
Canada
M59 TLB
I love my ZD326 but on rough ground the suspension seat is a back breaker.
Has anyone here tried installing an air ride seat on their zero turn? I'm looking for links to seat and suspension suppliers.
   / Air ride seat on a zero turn? #2
Following this, could be a good upgrade on my 54" ZT....
   / Air ride seat on a zero turn? #3
They do make just the air suspension that you use your own seat. "Little cheaper" . The whole unit gets pricey. Probably $600 and more. They do look nice though.
   / Air ride seat on a zero turn? #4
The air carriage thats used on the ZD1511 can go over to other models. Not sure on the ZD326, but it may fit.
   / Air ride seat on a zero turn? #5
The new Hustler Super Z HD I bought last spring came with a Grammer air suspension seat. I have some rough lawn and the air seat is a lot better than the spring suspension seat I installed on my old Hustler Z. I have chronic lower back problems and the air seat really helps. Many zero turn mowers have a common seat mounting bolt pattern, so a replacement seat is a bolt on install. The air seats are expensive, but to me very worth it if you have rough ground. Vic
   / Air ride seat on a zero turn? #6
I'm assuming you have adjusted your spring tension on the seat to balance your weight? The seats on the ZDs I think are some of the best seats Kubota has. You must be running over some very rough ground!!
2001 Ford F150 (A50121)
2001 Ford F150...
2019 Ford F-450 Service Utility Truck, VIN # 1FDUF4HT9KDA04609 (A51572)
2019 Ford F-450...
378811 (A51573)
378811 (A51573)
10ft x 8ft Container with Side Door (A51573)
10ft x 8ft...
2017 E-Z Beever M12R Towable Brush Chipper (A51691)
2017 E-Z Beever...
