Making a hole for snowblower chute control in my soft cab?
   / Making a hole for snowblower chute control in my soft cab? #1
atsah
Elite Member
Maine/Florida
John Deere 3025E
I bought a new Blizzard B54 3ph blower for my 1705, I have a clear Berco soft cab, the only way I can think of is with a soldering iron.. Any ideas? I like to keep things as manual as possible so I want to keep the manual chute.
   / Making a hole for snowblower chute control in my soft cab? #2
If you use a carpet knife and simply make a large + cut it should not be too difficult. you will have to remove the crank before you mount the snow blower and before you remove it to avoid ripping it by accident.
Good idea, it wouldn't let much air in the cab that way.
   / Making a hole for snowblower chute control in my soft cab? #4
When the shop guys were putting holes in conveyor belting, they would heat a bolt of the correct size, and melt a hole thruogh the belting. This method would probably work with the soft cab. A knife method may not cut a nice clean circle. Jon
   / Making a hole for snowblower chute control in my soft cab? #5
I can be wrong on this but as I understand it, the crank will be on the inside of the cab. If so, the cab will have to have a slotted hole as the crank will move up and down with the blower. I don't have rear hydraulics on my tractor so I bolted on a 12 volt winch to turn the chute. Many videos on YouTube on how to do this. I could never go back to a crank.
Al
   / Making a hole for snowblower chute control in my soft cab? #6
I would try to use heat to melt my way through. Drilling or cutting may leave a jagged edge which will lead to a stress crack.
   / Making a hole for snowblower chute control in my soft cab? #7
AH so they were big fans of Flexco fasteners for conveyor belts eh? I much preferred vulcanized splicing as there were no dust leaks from the splices.
   / Making a hole for snowblower chute control in my soft cab? #8
Back in the days, when I was still in manufacturing...... Jon
Well I guess I can mount a small worm gear motor for not much money, even a window motor would work, I'll post pictures when I get it done. I'm probably going to mount a 6 inch linear actuator as well, two dpdt switches and I'll be done I guess..
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A56129)
2020 KENWORTH T680...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2000 Ford F-650 Truck, VIN # 3FDNF6541YMA65799 (A54865)
2000 Ford F-650...
2007 Deere 650J LGP (A53314)
2007 Deere 650J...
2006 FORD F-250(INOPERABLE) (A55745)
2006 FORD...
2012 CATERPILLAR 140M2 MOTOR GRADER (A52706)
2012 CATERPILLAR...
