Dangers of angle grinders
   / Dangers of angle grinders #11
I was running one of those 4" paper thin cut-off wheel/blade on my Makita angle grinder. For whatever reason it simply grenaded. I only had on safety glasses and caught a chunk of the wheel in the face. It made a fairly deep & long cut. I ALWAYS wear a full face shield and leather work gloves when I use it now.
   / Dangers of angle grinders #12
I can't afford those great plastic disks with the abrasive material on them. They are high quality and do last a long time. I'm guessing, the plastic doesn't grenade.
So, I have a VERY BAD HABIT of taking the thin cutting wheels and using the side. It has a little flex to it, unlike a solid stone wheel. But it will probably fail, as the second failure I had recently experienced.
I know it could probably richochet off something, but I am always just mindful of the direction it will fly apart. I do wear safety glasses, and believe a flying disk will go through a face sheild.
   / Dangers of angle grinders #13
Skinny wheels (6" Metabo are the best) are quite useful, but dangerous as all get out. What usually gets them is when something binds, as they are quite delicate and won't tolerate any side loading. The key to success is to position your work so when it starts to separate it opens rather than closing on the disc, keeping your face, body and anything you don't want fragged out of the arc, keep a firm grip on the grinder and assume that it wants to hurt you.
   / Dangers of angle grinders #14
Speaking of vibration, hope you never have the guard on a 7" wildcat grinder come loose and get hung on the disc. Fortunately about 2 seconds of the shakes was all that happened.
   / Dangers of angle grinders #15
A Metabo "skinny" disc is exactly what bound up in the steel I was cutting, and it gave me a lovely looking long slice in my thigh.
UNUSED IRANCH 16" EXCAVATOR WOOD GRAPPLE (A54757)
UNUSED IRANCH 16"...
2001 MACK CH613 DAY CAB (A54313)
2001 MACK CH613...
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
Wright Sentar (A50120)
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
