Kubota L2900 turf tires to industrial R4 tires?
   / Kubota L2900 turf tires to industrial R4 tires? #1
tnrandy
Tennessee
YM336D
I have a L2900 that has 212/80-D15 front and 355/80-D20 rear. I'm looking to replace with R4 comparable tires. Looks like I can go with 28/8.50-15 Titan for the front, maybe? And I'm not sure what about the rear?
Any help would be appreciated!
Thanks
   / Kubota L2900 turf tires to industrial R4 tires? #2
I was in the same boat with my L3650 and that oddball 20" rear rim. I found a good assortment of tires at Tyres International - Home
Was going to replace my dry rotted turfs with more aggressive treads when a guy on craiglist had two like new front turfs and two lightly used rear turfs for $150.00. Couldn't pass on that deal.
That may end up being what I have to do...I found a R4 size that will replace the front but not the rear. I contacted Kubota for replacement rims and tires, taxes and shipping right at $2,500.00, which makes my "good deal" on my tractor not such a good deal.
   / Kubota L2900 turf tires to industrial R4 tires? #4
Thanks
I don't know if this helps but in seeking a softer ride I replaced my 12x16.5 OEM 6 ply R4s with 33x12.5x16.5, 4 ply (but still had the stiff sidewall to my demise, after receiving them....UGH) Titan brand turfs.
Difference in ride was about the same as was traction. I really thought I was going to get some improvement in ride quality going to 4 ply turfs....as it is, I puked 500 bucks. Traction with the R4 sucked in the first place so I wasn't worried about turf traction being worse when considering and it turned out to be without incident....I couldn't tell the difference.
To save a hefty shipping charge and to get a dealer discount, I went to my local Titan tire dealer and he ordered, received, and installed them. I had to wait about a week for his next truck, but for a hundred bucks of freight cost savings, I could stand that. Google the tire I got for $260 (which is bad enough) and the SRP will gag you. Titan was the only supplier of a turf for my 16.5 wheels to match the diameter of 33" since the tractor is 4wd.
Thanks
   / Kubota L2900 turf tires to industrial R4 tires? #6
There is a company that makes an R4 tread tire to replace the 20" turf. The guy I bought the turfs from had replaced them with R4s. For the life of me I can't remember the brand. He had ordered them from a local tire shop in Bardstown KY.
I wish u could remember their name. I called around and spoke to several tractor tire dealers all over and was told there is not a direct R4 replacement for the 20 tire. I知 leaning towards putting R4s on front as they have a replacement for that and putting new 20 turf on rear.
I値l search shops in Bardstown and see if I can find them. Thanks
   / Kubota L2900 turf tires to industrial R4 tires? #8
Suzuki Kingquad ATV (A51694)
Suzuki Kingquad...
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2003 SUZUKI VINSON 500 ATV QUAD RUNNER (A51247)
2003 SUZUKI VINSON...
2018 CASE IH 110N LOT IDENTIFIER 208 (A53084)
2018 CASE IH 110N...
2025 JOHN DEERE X350 LOT IDENTIFIER 153 (A53084)
2025 JOHN DEERE...
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
