555B - subframe-to-front support bolts
   / 555B - subframe-to-front support bolts #1
Chewwy
Upstate SC, Near the Electric City
Kubota L3240, MF 265, MF383
I inherited this tractor so I have little invested. On the downside, I don't know much about its history. I do know the engine was replaced with a rebuilt engine within the last 200 hours. It runs well and seems pretty strong. The hour meter on the dash does work and has less than 4,000 hours.
How many subframe to front support bolts should there be on each side? There are holes for 4 on each side.
My tractor has only 2 in place on each side. The online parts catalogue indicates only 4 bolts are required, but it's not clear whether this is 4 for each side or 4 in total for the tractor. The service manual is also no help here.
So how many subframe-to-front support bolts should there be on each side?
   / 555B - subframe-to-front support bolts #2
I'm working strictly from memory, so bear that in mind. I'm thinking there are 2 bolts on each side and 2 tapped holes in the front support on each side. The frame has 4 holes on each side which allows the same frame to accommodate both 3 cylinder engines (555) and 4 cylinder engines (655).
   / 555B - subframe-to-front support bolts #3
Two Bolts each side. Bolts when tight do not make a solid mounting to the frame. They allow some flexing between the two members.
   / 555B - subframe-to-front support bolts #4
That is correct
Thanks for the confirming that two bolts each side is indeed correct.
2023 HELI CPYD25C FORKLIFT (A58214)
2023 HELI CPYD25C...
2000 FORD F-350 SUPER DUTY (A58214)
2000 FORD F-350...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2012 John Deere TX Gator Utility Cart (A56857)
2012 John Deere TX...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
Eaton Air Compressor (A56857)
Eaton Air...
