Mahindra 26xl only starts by jumping solenoid
   / Mahindra 26xl only starts by jumping solenoid #1
ddberry88
Conroe
Mahindra 26 xl
Howdy,
So my late grandfathers tractor has been sitting for about 6 months. I've been out of state and recently back home to fiddle with it. I've replaced the batteries, battery cables and clamps, relay switches and checked all fuses. Checked the saftey switches as well. Problem is when I turn the key all I get is a buzzing noise coming from what I believe to be the relays. Bout 1 out of 3 tries I can get it to crank by jumping the solenoid, other wise when jumping the solenoid the starter will just spin but not engage. Was hoping someone might have an ideal of whats going on.
Ps. When I first turn the key on its like I have no power (hence gauges don't work or lights) but after a few minuets everything comes on....possibly a short somewhere?
   / Mahindra 26xl only starts by jumping solenoid #2
Have you found the "Search" function here yet?
Start at the battery, Check/clean all 'Grounds' (Earth) connections.
Follow the battery voltage with your multi-meter or test lamp...
Literally hundreds of threads on here with same issue. All colours.
Welcome anyway.
   / Mahindra 26xl only starts by jumping solenoid #3
seat and pto have a safety switch.... shuttle does also if its not hst.. one of them are bad or unplugged or not adjusted right
   / Mahindra 26xl only starts by jumping solenoid #4
Howdy,
A short would blow a fuse....
Did you replace the solenoid?
Hope the key is in the run position when jumping solenoid.....or you can mess more things up.
   / Mahindra 26xl only starts by jumping solenoid #5
Jumpering a solinoid is dangerous. You re messing with a LOT of current and the possibility of welding things together that were not meant to be welded together.
My vote is for the solenoid. On a lot of starters, the solinoid not only makes electrical contact between the battery and the starter but also pushes the Bendix gear out into the flywheel.
   / Mahindra 26xl only starts by jumping solenoid #6
AHHHHHH power surges... check your battery connections I bet the bands have almost corroded through...
   / Mahindra 26xl only starts by jumping solenoid #7
I see you replaced that already. Did you replace the main power wire all the way to the starter?
71068 (A49346)
71068 (A49346)
2015 CATERPILLAR D6K2 XL CRAWLER DOZER (A51242)
2015 CATERPILLAR...
E-Z Trail 675 Grain Cart (A50514)
E-Z Trail 675...
2014 JOHN DEERE 250D SERIES II OFF ROAD DUMP TRUCK (A51242)
2014 JOHN DEERE...
2005 FORD F650 4X2 XL SUPER DUTY FUEL/LUBE TRUCK (A51243)
2005 FORD F650 4X2...
2 Vintage Metal Signs (A48081)
2 Vintage Metal...
