Ford 445A CAV injector pump leak
   / Ford 445A CAV injector pump leak #1
jigggawatt
Phelan,California
Ford 445A
I just cleaned and resealed my Lucas CAV pump on my ford 445A tractor. It runs good but has a leak around the bottom large advance bolt. I think I知 missing something. I looked for a cracked housing but it looks good. I installed new orings and it still leaks. I see in some diagrams it shows a Dowty washer. I don稚 know what I知 missing. I have a new gasket and two new orings on the large bolt and a new sealing washer on the stud side, Thanks for the help.
   / Ford 445A CAV injector pump leak #2
Some/a lot of the older head locating screws have a steel washer also to collapse the oring.. it gets stuck up in the adv. housing on disassembly & lost during clean up..
it looks just like the steel line washer only larger..
IF your h. loc screw has 2 defined oring grooves, then you don't have the washer.. BUT if it has 1 oring groove by the top & no groove at the threads.. you need the washer.
Thanks for the reply. I have two orings. It sure looks like it痴 cut for a sealing washer where the bolt hits the housing. I don稚 have that size in the kit. I知 going to try to find one today. The housing looks good . I can take a mirror and watch it drip out ouf the side of the bolt. I致e even tried the square shaped orings .
   / Ford 445A CAV injector pump leak #4
that's a good pic.. it takes 2 orings & no steel washer.. The orings are in the kit..
JOHN DEERE WHP48A LOT IDENTIFIER 98 (A53084)
JOHN DEERE WHP48A...
2022 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2022 CATERPILLAR...
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
UNUSED JCT HYD AUGER (A51248)
UNUSED JCT HYD...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A51691)
2016 Toro...
2023 John Deere 6130M MFWD Tractor (A53342)
2023 John Deere...
