Have you seen the new CK2610?
   / Have you seen the new CK2610? #71
friend of mine bought a Kioti 2610, awesome tractor. http://www.tractorbynet.com/forums/kioti-owning-operating/372245-turning-up-fuel-ck27.html Hi guys I am from central PA I have a ck 25 and a ck2510 and i have turned up the pump on the CK 25 and yes you get more power I have access to a dyno and I went from 24.7 HP to 32 HP It really smoked when under a good load, It also made the paint burn off the stack so I screwed the screw in to 27 HP and the tractor works fine. I run a 15 K power plant and it has enough power to get the full 15 k out of the plant. the only problem is the Governor drop which is 200 RPMs under full load it will pull down 200 rpm and the governor will hold at that which screws up the cycles and voltage and bumping up the throttle will work fine until the load drops then you have to lower RPMs pain in the but. but it will carry full load. I have used this on the 1000 rpm and the problem is worse except this works well when we are not asking for the full 15k load. No on to the CK2510 it works better on the power plant because the gov drop is around 25 to 50 rpms Now this is a 24.5 hp engine with out computer controlled injector pump. Its actually a 35 HP engine detuned to 24.5. They turned the screw in and still could not meet the emission standard so they brought the max speed to 2600 rpm which is also the red line for the pto the CK 25 runs at 3200 rpm. Now with a shim removed from the timing at the pump I can get 37 out of the engine with also adjusting the screw. The first CK2510s were computer controlled but Kioti found out it was not needed so they took it off the newer ones which mine is. I also no longer have glow plugs they have air intake heaters, using the same principle as the glow plugs as far as the electrics go. the CK25 is gear drive and has been a good tractor and I have a 1000 hrs on the meter. I also had a 2410 which was more of a mower but had the features of the bigger tractor, was not a good tractor for me as it was always broke, so that hoe the CK 2510 came to be. which has been a disaster so fay the first round mowing in the yard I got stuck the FWD was not going in gear so 6 weeks later and many problems getting the parts I have the tractor back now at 50 hours the injector pump developed a leak its a 1000.00 part and is under warranty, Here we are a 50 hours and we are have 2 major issues with this tractor. I have a mmm and I installed the larger Ag tires and boy did that screw thing up all the mower geometry was off. I had to machine new pcs for lifting the deck the tires hit the deck. So I cant raise it up as you could with the borrowed turf tires. I had to make my own brackets to mount the mower on the tractor. It was supposed to use the FEL brackets which I did not get because I did not buy the loader. Kioti does not make separate brackets for my application. What a nightmare I will be running it in two weekends from now for 3 days straight at our tractor show for power with a leaky injector pump, this could get good. Their fuel tank placement leaves a little to be desired cause i need to fill for those 3 days with a five gall can, so I can see fuel being spilled all over the place. At home I have a pump. Well if I can be of help to anyone let me know at kkegris@yahoo.com by the way I am very good friends with my local dealer who is five mile away.
This sounds awful. Are The new ones that bad?
   / Have you seen the new CK2610? #72
What's the tractor show and where's it at? I'm in Perry County and I'd like to see what there is to see!
   / Have you seen the new CK2610? #75
But are the new ones any better?
The one I tested is an awesome tractor, right on par (in my novice opinion) with the Kubota L2501. I think you get a little more tractor with the Kioti, but they aren't quite the same shade of orange......
   / Have you seen the new CK2610? #76
email him, he'll tell you where the tractor show is, was, at.
Misc. Office Accessories/ Items (A53425)
Misc. Office...
WEILER S350 SKIDDER (A52707)
WEILER S350...
2008 Chevrolet C7500 Truck, VIN # 1GBK7C1G18F413382 (A54865)
2008 Chevrolet...
2017 KUBOTA SSV65 SKID STEER (A52706)
2017 KUBOTA SSV65...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A55302)
2020 Westfield MKX...
Scissor Lift (A55973)
