Need extension for top hydraulic lift
   / Need extension for top hydraulic lift #1
kubota shifty
Member
san francisco, ca
kubota 43h
I picked up a cheap harrow and the top lift isn't long enough for it to lay flat. The back is tilted up with the arm fully extended. I don't have this problem with my mower or box scraper. I have the quick-connects on the bottom lift arms so maybe that's causing a problem. Anyone know of an extension for the top lift? It just needs the right ends to extend the lift and allow the harrow to lay flat. Thanks!
   / Need extension for top hydraulic lift #2
You could just add a short length of chain.
Has to not be flexible. The hydraulics on the top lift needs to be able to lift and put down the attachment. I guess I could use a chain but it seems like it might damage the lift if it gets yanked suddenly.
   / Need extension for top hydraulic lift #4
Gravity puts it down. A chain will will work.
Or make one of these:
   / Need extension for top hydraulic lift #5
Spelling KUBOTA correctly should be less of a challenge.
Excuuuuuse me. The top arm lifts. I don't want to just fasten something to the harrow but lift it!
   / Need extension for top hydraulic lift #7
How does the top arm lift?
This is a 3 point top link:
What do you have, need pictures.
   / Need extension for top hydraulic lift #8
Why don't you go crawl back under the rock you came out from under.
Pics of your setup now would help a lot, then we can help with a solution.
   / Need extension for top hydraulic lift #9
If you can get us some photos of your harrow and top link it would help us come up with a possible solution.
   / Need extension for top hydraulic lift #10
I think he has hyd top link. So it will lift the rear as he is talking about. kabota shifty, still a piece of chain should be a simple solution.
My guess is the 3rd arm mount on the implement is not original. Could have a part missing on it but need pictures to have real idea.
UNUSED HURRICANE MSC2020F ALL-STEEL CARPORT (A51248)
UNUSED HURRICANE...
2007 International 7600 Tandem Truck, VIN # 1HSWYAHR37J478209 (A51573)
2007 International...
IRONCRAFT 84" ROTARY MOWER (A51247)
IRONCRAFT 84"...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A53472)
2019 Krause...
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
