Need extension for top hydraulic lift
   / Need extension for top hydraulic lift #1
kubota shifty
Member
san francisco, ca
kubota 43h
I picked up a cheap harrow and the top lift isn't long enough for it to lay flat. The back is tilted up with the arm fully extended. I don't have this problem with my mower or box scraper. I have the quick-connects on the bottom lift arms so maybe that's causing a problem. Anyone know of an extension for the top lift? It just needs the right ends to extend the lift and allow the harrow to lay flat. Thanks!
   / Need extension for top hydraulic lift #2
You could just add a short length of chain.
Has to not be flexible. The hydraulics on the top lift needs to be able to lift and put down the attachment. I guess I could use a chain but it seems like it might damage the lift if it gets yanked suddenly.
   / Need extension for top hydraulic lift #4
Gravity puts it down. A chain will will work.
Or make one of these:
   / Need extension for top hydraulic lift #5
Spelling KUBOTA correctly should be less of a challenge.
Excuuuuuse me. The top arm lifts. I don't want to just fasten something to the harrow but lift it!
   / Need extension for top hydraulic lift #7
How does the top arm lift?
This is a 3 point top link:
What do you have, need pictures.
   / Need extension for top hydraulic lift #8
Why don't you go crawl back under the rock you came out from under.
Pics of your setup now would help a lot, then we can help with a solution.
   / Need extension for top hydraulic lift #9
If you can get us some photos of your harrow and top link it would help us come up with a possible solution.
   / Need extension for top hydraulic lift #10
I think he has hyd top link. So it will lift the rear as he is talking about. kabota shifty, still a piece of chain should be a simple solution.
My guess is the 3rd arm mount on the implement is not original. Could have a part missing on it but need pictures to have real idea.
2018 Seal Rite SR 700XP Seal Trailer (A52384)
2018 Seal Rite SR...
40' CONTAINER (A51248)
2012 Dodge Charger Passenger Car (A51694)
2012 Dodge Charger...
(4) STEEL CARTS W/ WHEELS (A51248)
(4) STEEL CARTS W/...
