4wd Mahindra 4025 pin touching driveshaft
   / 4wd Mahindra 4025 pin touching driveshaft #11
From what it looks like you may just need to tighten it a bit to raise it up... it should only have a space between it the size of a nickel... what I would be worried about is if the shaft only hits in on partial rotation meaning you shaft has some type of bend or give to it...
Is it resting on the shaft or no? I see the marks were it hits it
Much appreciated! And yes it is resting. I have a leak somewhere and just assumed that was it.
Wow, good point, I don't think so but will double check. From what I could tell the mark was all the way around.
   / 4wd Mahindra 4025 pin touching driveshaft #14
just try to tighten it a bit if the shaft has no movement..
put the oil on your finger and smell it I bet its fuel leak actually if anything there are a few braided lines above that exact spot that are common to leak.
10-4 will do, thx, will check back in if there's any other development. Again, much appreciated fellas.
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2014 Isuzu NPR-HD Landscaping Sprayer Truck (A50323)
2014 Isuzu NPR-HD...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
2014 BMW 328I (A50120)
2016 John Deere 6130M (A50120)
2016 John Deere...
2019 Chevrolet Tahoe SUV (A50324)
2019 Chevrolet...
