B7510 or B7610 Service Manual / Wiring Diagram
   / B7510 or B7610 Service Manual / Wiring Diagram #1
Semms
PA
Kubota B7510
Hi,
So I'm hoping someone can help me out. I recently bought a used b7510 TLB and have decided I need to add an alternator for work lights. I purchased a pdf version of the service manual and unfortunately it contains everything but pages 9-M1 and 9-M2 which would be the wiring diagrams. Does anyone have those pages or an equivalent wiring diagram? I don't even need a scan, a readable picture of it from a phone would work.
I'm working on adding the 40 amp alternator and wiring it the same way the wiring harness from the kit is wired and I'd like to check the diagram before I proceed.
Thanks,
Semms
   / B7510 or B7610 Service Manual / Wiring Diagram #2
Send me private message with your email and I'll scan in the pages and send them to you.
Mike
   / B7510 or B7610 Service Manual / Wiring Diagram #3
Hi,
Thanks,
Semms
Just a suggestion, go with LED’s and make no changes to your existing alternator/dynamo.
Good luck!
Thanks Mike, PM sent.
bg71361,
Thanks for the suggestion but the wimpy dynamo can only handle one of the LED light bars I installed. I have a 20" led light bar facing forward that draws 10.5 amps. I plan on adding 3 36watt led lights facing rear for backhoe work. One facing straight and one each off to the sides.
2014 FORD F350 (A60460)
2014 FORD F350...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
New/Unused Heavy Duty Brush Cutter (A57454)
New/Unused Heavy...
2013 BMW 328i Sedan (A56859)
2013 BMW 328i...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2021 SANY SY265C LC LONG REACH EXCAVATOR (A59823)
2021 SANY SY265C...
