Serial number on Massey 275
   / Serial number on Massey 275 #1
Bassmanks
Garden City Kansas
Massey 275
I have a Massey Ferguson model 275 with a missing serial number plate. I need to do some clutch and I'm not sure if it is a single or two stage clutch. Is the serial number stamped any where else on the tractor? It is a Diesel. Thanks in advance.
   / Serial number on Massey 275 #2
I cannot help you with your serial number, that tag is normally the only place that will have it. Does your tractor have independent pto? If so it will have the single clutch. Live pto models are the ones with a dual clutch setup.
not sure but I think it has a live pto. I have a lot more to learn. Thank you for your help I will probably be reaching out in the future. Ray
   / Serial number on Massey 275 #4
If you have live pto, when the pto is engaged and you step on the clutch the pto keeps turning. Some people refer to it as a tractor with live power.
   / Serial number on Massey 275 #5
Ps. Welcome neighbor, I'm on the other end of the state near Topeka.
   / Serial number on Massey 275 #6
Hi.
The 275 has a 12 inch two stage clutch unless it has independent power take of, this can be found by ,starting the engine and moving the pto lever ,the one on the left hand side under the seat if the lever moves without gears crunching it has a two stage clutch.
Hope this helps.
Hutch.
Thanks guys for your help. I'm sure I'll have more questions as this restore project unfolds.
2020 FREIGHTLINER CASCADIA SLEEPER (A57880)
2020 FREIGHTLINER...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A57024)
2023 Kubota...
(20) 2" X 4" X 30" TUBING (A57192)
(20) 2" X 4" X 30"...
2018 VOLVO VNL DAY CAB (A52576)
2018 VOLVO VNL DAY...
2018 Chevrolet Silverado 3500HD 4x4 Crew Cab 9FT Flatbed Truck (A51692)
2018 Chevrolet...
2015 Toro Workman MD Utility Cart (A53421)
2015 Toro Workman...
