George2615
Super Member
Got a snow blower for my tractor. I wasn't really looking for one since my front QA snow plow is doing a great job plowing snow. While scanning the web the other day and I found a used older Lorenz 730 series double auger blower for sale at a price that was too good to be true. I know its an older model because 1) Newer models have paddles in the center of the augers that push snow into the fan and 2) it has a 3 blade fan and newer ones have either 4 or 6 blade. A brand new 7' double auger Lorenz with hyd. chute rotation sells for 5K and this one was less than 2K so I bought it. All the warning labels look new but the prev. owner always kept it garaged when not in use. Got it home last night and put in garage this morning. Pulled, cleaned, and lubed PTO shaft and U-joints. Replaced all shear bolts and installed spares in the holes provided. Serviced gearbox. Cleaned, lubed and adjusted chain. Cleaned and lubed chute rotating parts. Adjusted skid shoes. Sanded and primed rusty scratches and I'll repaint the whole thing this spring. I still have to install a flow restrictor in the chute rotation hose because it turns way too fast. Made some slight mods so it fits my quick hitch. Hooked it up and tested by backing into some snowbanks I have piled up and it works fine. Will try it on the next snow we get. Plus its an extra 700 lbs on the 3 pt so more weight for plowing. I've added a link to a new model version of my blower.
84" Lorenz 3-Point Tractor Snow Blower Model 731
